Forced Air Velocity Stacked Deck-Mod
Old 10-01-2010, 03:39 PM
  #61
Staff
DeathCougar's Avatar
Originally Posted by sebastianholmes
yes the truck will keep running with your hand over the hole, its an airbox its made to keep it running with the intake is covered by things like water. if you held it there for 5 and there was an airtight seal around your hand and it kept running then yea id say its not airtight. otherwise i think its got a pretty good seal.
That was my point. I could keep my hand there all day and it would keep running. The airbox is NOT airtight. And if you get that much water up that close the the airbox it WILL suck it in. But thats a completely different topic
The point is, the airbox isn't sealed so even IF the fan could push enough air for forced induction, it wouldn't make a difference.
DeathCougar is offline
Old 10-01-2010, 03:45 PM
  #62
sebastianholmes's Avatar
alright i wasnt sure if thats what you meant. never checked to see if the box was airtight. and yea that does make a fan completely pointless. just get a real TRD supercharger
and i know the airbox will suck water in. had to scoop a little out once lol
sebastianholmes is offline
Old 04-26-2011, 01:50 PM
  #63
SharpStick's Avatar
Hmmm, as there's an initial drop in pressure at the instant the throttle-plate opens (created by the mechanical pumping action from the engine - the suck), so the little fan that might could serve to compensate for that pressure drop, essentially improving low-end throttle response. That fan will run out of mustard pretty quick, though, so I can't see any improvement beyond improved tip-in. Did dyno results appear anywhere in this thread?
As for the stack mod being dyno-proven, it was very dyno'd, with scientific method all over the place. Stop being a doubter.
Whether or not the airbox is airtight (which it ain't), how much does it bleed versus the air headed in?
STICK
SharpStick is offline
Old 04-26-2011, 03:22 PM
  #64
mastacox's Avatar
The pressure in the intake is lowest (vacuum) when the throttle plates are closed. As soon as they open, manifold pressure increases. I don't know what you're talking about with "drop in pressure."
That fan is incapable of generating any pressure differential. It doesn't have the power or flow rate required.
They didn't. And for good reason- any gains would only be comparable to that of a plain jane deckplate mod.
Please provide an example of your "scientific method all over the place." Specifically, provide proof a velocity stack will do anything when placed before the air filter in the intake of a fuel injected engine.
mastacox is offline
Old 04-26-2011, 03:41 PM
  #65
Staff
This.
Also, this ridiculous thread has gone on long enough without any proof.
Lets see some proof, or I am going to close the thread for misleading/incorrect information.
Old 04-27-2011, 06:14 AM
  #66
mastacox's Avatar
For those that are unaware, the REAL reason velocity stacks have the curved intake isn't because it increases velocity. The radius prevents an eddy from forming at the corner of the intake, which reduces the effective hydraulic diameter of the pipe. Of course a 4" intake is large enough that this isn't an issue in our case anyway...
In the case of a 4" diamter pipe, you need a curve radius of about 1/2" to prevent eddys from occurring, but even if they do occur it isn't a large enough effect to affect the intake's resistance compared to say sucking air through the filter.
mastacox is offline
Old 04-27-2011, 06:43 AM
  #67
Fink's Avatar
pwned.
Fink
Fink is offline
Old 04-27-2011, 06:47 AM
  #68
mastacox's Avatar
Originally Posted by Fink
pwned.
Fink
Indeed.
mastacox is offline
old87yota
09-09-2015 12:39 PM
Squigglez
09-04-2015 07:33 AM
oldpickupguy
09-01-2015 05:46 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
this_guy
07-31-2015 01:27 PM
Quick Reply: Forced Air Velocity Stacked Deck-Mod
