View Poll Results: Do you gap you plugs?
Voters: 139. You may not vote on this poll
Do you gap your plugs?
Originally Posted by Lone4runner
outta the box dont know how i would gap the platinums 4's
Originally Posted by Blair
Pretty sure you can't gap those.
I've always 'heard' that standard plugs can be gapped, but don't need to be. and that platinum plugs (any kind) should NOT be gapped. That is the reason for this pole. I'd like to see what others are doing. Most often I will check the gap with a feeler gauge and only once have I ever had to actually adjust to spec. But I think I dropped that one, trying to get it in the darned "5" hole, which ALWAYS gives me a hard time. In fact, I think I have a used plug sitting on that little shelf under the cylinder bank right now which I dropped on extraction.
i gap mine to .040, i'm running an accel super stock coil. makes it easier to start the engine.
Originally Posted by Ganoid
I gap mine to .065 every time.
I always check the gap. Densos and NGK's are usually OK out of the box but occasionally one needs adjustment. When working on my old big block Ford, they always need gapping out of the box.
