Diff fill bolt is stuck
Old 02-23-2007, 04:21 PM
UK Drew's Avatar
yep its 24mm, and if you cannot weld a nut onto it then i would just whip it off with a chisel mate, bet you anything someones put an inch socket on there once too often and rounded it off.
Old 08-13-2009, 12:03 AM
hellfire's Avatar
Man mine is rounded, I have used a grinder to put a little slot in the middle of the plug and I bashed the crap out of it with a cold chisel and hammer.. It ended up cutting through the bolt, rather than loosening..
I have tried 6 sided 24mm socket, 12 sided 24mm spanner I especially bought for the pickup.. Next step is welding.
Old 09-09-2009, 11:54 PM
LooseNuts's Avatar
x3 or 4 or what ever it is so far on the cold chisel. have gotten 3 out like this so far (2 different trucks)
Old 03-31-2015, 09:25 AM
Rubberneck's Avatar
I know this thread is old but I just ran into this problem yesterday. I don't have a torch so I hit it with a hammer. No luck. Finally I just stuck the ratchet on there and positioned it at about 4'oclock. Got my floor jack and raised it right to the end of the ratchet handle. Moved out of the way and gave it 1 pump. Bolt broke loose instantly.
polo451
13
11-20-2016 07:49 PM
fountain
12-31-2015 06:08 AM
Steven.m.paulk
07-24-2015 01:44 PM
whereAreMyPants
07-22-2015 03:32 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Diff fill bolt is stuck
