cup holders in first gen 4runner and second gen trucks
So awhile back I read on one of the forums about someone putting a vw passat or jetta cupholder into our trucks. So after looking for awhile I finally found one out of a passat and installed it into my 4runner and it works great. So i thought id share with you my solution to the cupholder problem everybody seems to have with our trucks. This set up cost me under 20 bucks.
So here is what you need.
First you need to find a cupholder at a junkyard or online. I would recommend a junkyard way cheaper then online
Next you will need to buy some 3m double sided tape
Then you will need to make some type of support or find something that will work. I used a plastic piece of a 4runners roll bar and that works perfect. I had an extra one in my garage.
Then you will need to attach the double sided tape to the top of the cupholder, to the inside part of the plastic piece so it stays in place and to the top of the support as well
Then you carefully slide the cup holder in place so its flush on both sides of the radio bezel thing. And then you have cupholders that almost look like factory and work great
if you have any questions let me know
i think its 2000 and newer passat or jetta I got mine out of a passat
here s a picture of my truck in 5th with the cup holder out
That's what the support thing is for so it doesn't come off and the cup holder has like rubber things to hold the cup trust me it work great and isn't that far of a reach
A quick update On this it's still working great haven't spilled a drink yet. I changed how I mounted it I used a metal strap and ran it underneath and used the pre existing screw holes on the side of the radio area and it's holding up great.
Ya I had that problem too but I ended up moving my cb under my passenger seat. I figured i use my cup holders almost everyday and I only use my cb every once and awhile
