Catastrophic 22RE FAIL!
Old 09-08-2009, 12:05 AM
9o7yota's Avatar
Dude.. this makes the first time ive heard of someone actually doing that to a 22re. If you did that...wow dude... good luck with the rebuild if u end up doing it. im knee deep into mine so ill help u out if u have questions
if the guy before u hydo locked it..haha.. thats exactly why he sold it. That destroys bearings, and at high heat when it happens, the thrust stroke of the engine and the coldness of the water cracks the rods... dude...thats a nasty hole... im sorry man... samurai swords have their limits too i guess haha
Old 09-08-2009, 08:54 AM
BigBluePile's Avatar
Originally Posted by Plumbrbob
Update I jsut got done removing this motor and the block blew out from both sides the starter took a good hit and was destroyed the clutch puck also took a shock load and warped it good.
after closer inspection it seens as if the ROD BROKE IN HALF the piston is slammed into the head and the rod bearings are perfectly intact free spinning
pics soon I have to get the peice of junk to my house first
Rob, that is ridiculous!!! Good to hear the motor is stabbed and ready for fire!
Old 09-08-2009, 08:58 AM
rdrttoy's Avatar
would it run with the hole in the block?
Old 09-08-2009, 10:29 AM
toyota4x4907's Avatar
YouTube "22r Rod Knock Blow up part 3"
Old 09-08-2009, 04:01 PM
  #25
Plumbrbob's Avatar
This motor is not rebuildable the block is toast the head toast thanks for the offer on the help I'll hit you up if i need something.
This wasnt my motor and I did not buy it its 85runnerdads' motor it was roughly a 1 1/2 yr old reman . I talked to him about that day he hydro locked and he swears up and down he shut it down before damaged occured.
SO WHY WOULD A ROD BREAK IN HALF??????
I bought an used 22re and got r in his rig last night so jsut a quicky swap out
Old 09-08-2009, 04:03 PM
  #26
Plumbrbob's Avatar
This motor would not run since the starter blew up
Old 09-08-2009, 05:54 PM
  #27
86Toyrunna's Avatar
wow.. thats epic... i love seeing a great catastrophic failure.heck thow her up on craigslist and say that its got a custom crankcase vent and/or custom inspection hole lol aint nothin a lil jb weld and silicone cant fix.
Old 09-13-2009, 09:39 AM
  #28
Plumbrbob's Avatar
here are some pics as I take the block apart I will post up rod breakage soon when I get it out
piston head is cracked
intake valve is bent
What is your guys take on how this motor was running? now that we can see its guts
ALSO I put a healthy 22re motor in 85runnerdads runner it was a queit runner with 190-195 compression numbers and no noises ....now that perfect motor is in his runner it has a lifter tick and he claims all 3 motors that he has had in the past few years have had this lifter tick?????
ANY THOUGHTS??
Old 09-13-2009, 04:09 PM
  #29
Staff
DeathCougar's Avatar
I doubt its lifter tick, its likely a fuel injector issue. They can tend to be pretty loud. Did you use the injectors from his 4Runner, or the donor truck?
Old 09-13-2009, 04:30 PM
  #30
You have two sets of injectors now right Rob? As long as they are the same connector, just get the one set sent into Witchhunter.
Old 09-13-2009, 05:27 PM
  #31
Plumbrbob's Avatar
I have the original motors injectors, 85runnerdad is using HIS original injectors, I mentioned to him that it must be HIS injectors causing the issue......I was jealous I made the deal with him on that motor since it was such a healthy runner.
Old 09-13-2009, 05:29 PM
  #32
Plumbrbob's Avatar
the motor we speak of is not in my possesion nor do I have control over it , I will message him this great idea though of having the injectors rebuilt.
  #33
Plumbrbob's Avatar
dont you think this motor was running a bit rich? how can a motor just over a year old have so much carbon build on it
the injectors must be all over the place
Old 09-13-2009, 05:30 PM
  #34
Heck yeah man, they're crazy fast too! It's possible to get the injectors back in three days if not sooner.
Old 09-13-2009, 05:33 PM
  #35
Plumbrbob's Avatar
before I convert to EFI I will be having this witchhunter work done
Old 09-15-2009, 06:41 AM
  #36
SpENtBrASs's Avatar
damn that really sucks. i always thought the 22RE was indestructible...
Old 09-15-2009, 10:32 AM
  #37
83
83's Avatar
No such thing. Nothing can take serious abuse and keep going forever.
Old 10-17-2009, 08:45 AM
  #38
Ron Helmuth's Avatar
seems excessive?
Could we get an answer to the carbon buildup question? From an engine type of guy?
It appears to be flaking away-I am looking at the photo with spark plug still in place- and where would that stuff travel to within the engine?
I'm no expert-but this is how I learn.thanks for posting up the pics so we have a frame of reference.
Old 10-17-2009, 10:00 AM
  #39
crawlerjunkie's Avatar
They are indestructible, until you put a hand grenade in one of the cylinders.
Old 10-23-2009, 12:13 PM
  #40
Jay351's Avatar
Or a few cups of water...
Blamalam
03-12-2022 07:34 AM
JNapolitano
11-14-2019 07:46 PM
accuracy
08-04-2015 08:05 PM
1994toyota
07-17-2015 03:03 AM
Quick Reply: Catastrophic 22RE FAIL!
