Any tips for attaching hoses to barbs?
Old 07-03-2010, 10:39 AM
pendrag's Avatar
When I did my first ATF cooler install, the toughest part for me was getting those 3/8" ATF cooler hoses onto the various barbs at the connections. I ended up grabbing the hose in some slip-joint pliers and twisting it on. I even tried soaking the hose in boiling water first.
Is there a trick to getting hoses to slip on more easily? I'm installing another cooler today and I'd like to save myself trouble.
Old 07-03-2010, 10:49 AM
swampfox's Avatar
lube up the inside of the hose with some trans fluid. it will help a little.
Old 07-04-2010, 07:38 AM
wyoming9's Avatar
Red face
I use Silicon spray on all my slip on fittings it works wonders
Old 07-04-2010, 03:22 PM
85gijunk4x4's Avatar
crc336.
also stick needlenoose pliers in the hose hole, heat around the pliers and then open them to stretch the hose, but dont strtch it too much
Old 07-04-2010, 08:54 PM
Green93's Avatar
x2 on the silicone spray. It works amazing to put rubber hoses on.
nvdesertrunner
05-11-2020 08:18 PM
Jcrawl94
10
10-24-2015 04:34 PM
WellsR
12
07-31-2015 03:27 PM
Sr5crawler
07-31-2015 12:32 PM
80Truck
07-24-2015 03:12 PM
Quick Reply: Any tips for attaching hoses to barbs?
