The almost impossible 22re crank bolt
Old 01-02-2011, 05:48 PM
blackyota4x4's Avatar
I've been trying to replace the timing cover gasket for a while now but have been unable to get the crank bolt out to get to it. I tried all the old tricks, PB blaster, huge breaker bars with 6 foot cheater pipes, a hammer and chisel, I tried heating it with propane torches, the starter trick, 600lb ft torque impact gun from harbor freight (HF). The Dang bolt would just laugh at me in my face. Finally I picked up a 3 inch air cutter from HF and I was able to angle it in enough to get me just shy of the pulley. Then I hit it with a 2lb hammer and steel chisel and I was able to spread the gap just a bit. After all that trouble I hit it with the starter trick one last time and VOILA!! Darn thing came right off. There's some kind of red stuff on there I'm assuming the numb nuts previous owner rubbed it down with thread locker.
I can't believe how many hours I spent on this thing like a monkey making sweet love to a football. I'm just glad this nightmare is finally over and I can work on fixing this pesky oil drip.
Make sure you take the radiator out to give you plenty of room to work.
I measured about 7 inches between the bolt head and the front of the truck to work in, just enough room for the HF earthquake impact gun and short 19mm impact socket from craftsman.
LC engineering sells replacement bolts for 9$
I hope this will help some of you guys. Good luck and don't get discouraged just find a better tool.
Old 01-02-2011, 05:56 PM
Bandito's Avatar
Old 01-02-2011, 06:04 PM
yotarob2005's Avatar
Good job, you showed perseverance. Most folks would have gotten discouraged and quit. I like your style, just get a better tool and try harder!
Old 01-02-2011, 06:17 PM
Thanks buddy I'm stubborn as a mule.
here's a pic of the crank pulley after the pulley chain wrench had her way with it. It's just an excuse to upgrade to some high speed LC engineering gear
sandyota
02-04-2021 11:16 AM
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
v_man
07-23-2015 04:01 PM
redneck17
07-17-2015 07:44 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: The almost impossible 22re crank bolt
