$600 CUSTOM rear bumper for 2nd & 3rd gen!
Old 07-26-2005, 06:45 PM
yeaitsme's Avatar
its a sprayed finish,just your typ durable refinish paint.i also leave them bare for a cheaper price if you want them powdercoated..
Old 07-26-2005, 07:14 PM
rocket's Avatar
BCC (Taran) came through with pictures only a couple hours after i sent him an email. Heres what i got for ya'll...
More of Daryls 2nd gen:
The long awaited 3rd gen:
This is first time ive seen this front bumper and im drolling over it. Simply amazing. I may be getting one along with the rear.
P.S. The paint job is just your basic primmer and rust preventive spray.
Why dont he use powder coating?
In his words: Its much easier and looks nicer when you "touch up" paint. Powder coat looks like crap when you touch it up with paint. Powder coat can chip off in peices and water can cause rust under the existing powder coat.
Paint is cost effective for both the buyer and seller. The bumper is designed for off roading and is built to take abuse so powder coating it would be pretty much pointless.
I agree.
www.bigcountrycustoms.com
Old 07-26-2005, 07:21 PM
garrett1478's Avatar
mmm that 3rd gen bumper is nice
Old 07-26-2005, 07:27 PM
Marc P's Avatar
That is a sweet bumper, but I like the tube bumpers better, and much less $$
Old 07-26-2005, 07:31 PM
  #25
Crux's Avatar
Wow, that is an awesome bumper.
From that one pic of the 2nd gen, it looks like the swing-away tire carrier is removable if you don't want to drive around with it all the time - is that right?
Also, how does this attach? Bolt-on, drill new holes, weld, ?
Old 07-26-2005, 07:48 PM
  #26
One More Time's Avatar
Are the sides of the rear bumper secured to the frame?
Old 07-26-2005, 07:51 PM
  #27
yeaitsme's Avatar
the whole swing away is removable except for the weld on fully machined spindle.its machined from solid steel then welded to the bumper.the 3rd gen i like to build a rear x-memeber in the end of the frame, to make it more rigid. there fairly weak stock back there.that one also shows the jerry can holder which is removable.
Old 07-26-2005, 07:54 PM
  #28
rocket's Avatar
"midiwall" posted 2 non-chopped pictures of the bumper without the tire carrier (all the 2nd gen pics are the same 4Runner owned by "DarylD") so you can see its removable.
The bumper is 100% bolt on. The center beam has squared tubing that actually slides into the end of your frame (the 3rd gen may be different).
Heres a pic of how the side can be attached but BCC told me hes using the 2 stock holes in the sheet metal with a bracket to connect the bumper sides to the body (same place where the stock bumper attaches).
Old 07-26-2005, 07:55 PM
  #29
yeaitsme's Avatar
yes they are i think in the last pic you can see the 1"by1" tube that goes across.it also has a side mount that bolts to the stock weld nuts in the body for a little axtra.i make it all bolt on except for the mount tabs that hold the side wings.i usally weld them to the frame and give it a little tack after words so even if the bolts do come loose it wont move around.but if im not installing it,and you have no means of a welder.i can make bolt on mounts.
Old 07-26-2005, 07:59 PM
  #30
rocket's Avatar
Thanks Taran, Its good to see you here and explaining the stuff i dont know or forgot.
Old 07-26-2005, 08:17 PM
  #31
dragr1's Avatar
Do you have any pics of the frame mounts on the 3rd gen unit? I'm curious to know if it will handle the tire/tire carrier and still hold up to the factory tow rating of 500 hitch weight pounds and 5000 trailer weight pounds. I'm not doubting the bumper (that is one sweet bumper), I'm just curious to see the mounts.
Old 07-26-2005, 08:22 PM
  #32
rocket's Avatar
Unfortunately i dont. Ive asked "DarylD" but he didnt say wether or not he had any.
Hopefully "yeaitsme" can come up with 'frame mounted pics' for both the 2nd and 3rd gen....
Old 07-26-2005, 09:01 PM
  #33
yoda-g2's Avatar
Hmmmm, I'm very interested in this. Is it posible to get the 3rd gen version without the side hoops? I'm also want to make sure about the tow rating. I tow about 5000-6000 lbs around a few times a year.....
Old 07-27-2005, 04:22 AM
  #34
Co-Founder/Administrator
Staff
Corey's Avatar
From an old trail run we went on years ago, a stock pic of Daryl's rig
It has come a long ways Daryl.
Old 07-27-2005, 05:44 AM
  #35
99_Runner's Avatar
That is a very nice bumper. Wish I had the cash to get one right now.
Old 07-27-2005, 07:54 AM
  #36
Epic Ed's Avatar
What's that white stuff?
Old 07-27-2005, 08:11 AM
  #37
mastacox's Avatar
1) $740 for the bumper with tire carrier and painted black (gloss, low gloss,
or flat).
If you have a 1" BL, add $62 to whatever option you choose.
Yikes, if only I had $802 that bumper is sooooo bad ass...
  #38
mastacox's Avatar
Looks like some kind of wierd volcanic ash
Old 07-27-2005, 08:34 AM
  #39
Epic Ed's Avatar
Yeah...that was my guess. They are in Washington, right?
Old 07-27-2005, 08:54 AM
  #40
PAhydrohead's Avatar
Are the reversing lights in the 3rd gen bumper pic an option also or were they added later. Nice touch.
Quick Reply: $600 CUSTOM rear bumper for 2nd & 3rd gen!
