22re swap to 22r
Old 09-05-2010, 02:47 PM
dlgrafton09's Avatar
I'm doing the same thing! I'm almost done, just down to finishing the vacuum lines and electrical stuff. Does anyone happen to know if gas will flow through the electric fuel pump if I pull the fuse and let the manual do all the pumping?
Old 09-05-2010, 03:03 PM
swampfox's Avatar
dlgrafton, you will need to pull the electric pump it will cause you problems.you can find the 22r tank parts at the salvage yard.
Old 09-05-2010, 07:24 PM
85gijunk4x4's Avatar
hey dlgrafton, how did it go? was it easy, or hard, or medium? lol.
im just curious...but do you have any tips or pointers your willing to share?
and how was it to change over the electrical and vacuum lines?
Old 09-05-2010, 08:03 PM
Wink
I got the whole engine and dropped it in with no problems. My husband and I got the engine in the compartment monday and I have done the rest while he's out on his hitch. I've only ever changed one engine and both of them were EFI. This has been somewhat challenging what with all the little things I had to consider and how to work around them. It's been medium, but would have been easier if I had an all day babysitter LOL.
Pointers...only one person should be taking bolts out or both should be watching. I have had to be creative when guessing what boths are supposed to go where. Still am working on the wiring...I'm gonna have a lot of taped up empty plugs and still have to figure out how to use what I can like finding the plugs for the oil pressure switch and sending unit. Have to find something to do with the wires coming from the carb that don't have anything to plug in to. Since the body is EFI, I am missing some aspects of the vacuum system, but I think I have creatively combined the two...somewhat. Will know by Tuesday if the thing is gonna run...wish me luck...
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
deepmarsh
08-06-2015 03:44 AM
cars-guy
07-11-2015 07:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: 22re swap to 22r
