2004 toyota sienna AC not working
Old 09-25-2013, 06:00 AM
fatboysam's Avatar
My cars AC was working fine till last month, then it would switch ON/OFF intermittently for 2-3 weeks, but now its NOT working at all. I don't hear the AC clutch getting engaged...
The local mechanic diagnosed it with AC clutch problem... he spent only 5 mins in diagnosing this.. he is asking $350.00 in parts and labour for replacing the AC clutch..
My question : Is it possible that AC clutch is not engaging because of low R134a? looking at the symptoms I described above..
Will it hurt if I add half can of r134a and see if the clutch gets engaged... can that damage anything else?
Old 09-25-2013, 06:10 AM
j2the-e's Avatar
Yes, a low charge can cause your symptoms. Adding 1/2 can probably wont do any good. I imagine your mechanic hooked up some gauges to check for refrigerant. Or at least he should have. There is a good chance your mechanic is correct. It's an easy diagnosis. However, I have seen magnetic clutch relays fail on those as well. And be warned: If the clutch has in fact failed, odds are good the compressor is on its way out as well
Old 09-25-2013, 06:27 AM
fatboysam's Avatar
Thanks for the prompt reply, do you have any recommendation on where I can buy Only the AC clutch?
Old 09-25-2013, 06:34 AM
j2the-e's Avatar
Dealer. Any local auto parts store. Ebay. Amazon. Try swapping the relays too. Horn relay is the same I believe.
If you do replace the clutch, it's replaceable without removing the compressor. Drop it down a little and remove the subframe bracket below it to gain access
gog1968
06-22-2015 05:55 AM
2wdtundra
06-17-2015 01:41 AM
Toddski
07-08-2002 05:42 PM
Quick Reply: 2004 toyota sienna AC not working
