20/22r hybrid question
Old 05-18-2010, 09:09 AM
Airo Spade's Avatar
Iv been looking for 2 weeks so here I am. Does anyone have alot of information about this swap. No how to do it but specs, dyno hell anything other then it will increase the air flow in the engine by 200%. Thanks
Old 05-18-2010, 09:37 AM
yotaman85's Avatar
you will need a late 20r head and an early 22r block. you will also need the 20r intake manifold, but you can use the 22r exhaust manifold. you should also look into adapting the 22r carb over to the 20r intake because the 20r's had a water choke. I am not completely sure on all the details but it does have a few more little things you need to look out for.
also. it does not increase air flow by 200%, it just increases air velocity into the combustion chamber.
good luck..
Old 05-19-2010, 07:25 AM
Airo Spade's Avatar
so increasing the airflow into the chamber does what and if i want to have a forced induction engine will doing that benefit anything at all. Yes Im a noob
Old 08-15-2010, 07:37 AM
82hilux671's Avatar
just asking
but im thinkin of slammin a 20r head on my 22r i have been searchin the forum but just want to make sure so all i need to make the swap complete is the
-20r head
-20r intake
-22r conversion gasket for the carb
will the 22r timing chain work or will i have to get another one???
thanks for the input
Old 08-15-2010, 07:47 AM
xxxtreme22r's Avatar
please when talking about the 20r/22r hybrid conversion, please state what year your truck is. this makes a major difference in what will and will not work. Better yet, add this info to your signature and you won't have to let everyone know and noone will have to ask.
Old 08-15-2010, 07:55 AM
now with that said, I am assuming by your screen name 82hilux671 yours is an 82 using the 82 22r block. Your timing chain should be a dual row timing chain. which means your 20R head is also a dual row timing chain so yes, it will work.
if the block is from an 83-84 22r then that would be a single row timing chain and cover and the dual row 20R head will not work. You would have to convert the single row timing cover etc to dual row for it to work.
Old 08-15-2010, 08:08 AM
82hilux671's Avatar
yeah thanks i forgot to mention that but yeah its the first generation 22r i just wasn't if the 20r was dual row or not
thanks though
06-01-2021 01:51 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: 20/22r hybrid question
