1st Generation Toyota 4Runner's.....
#81
heres mine in Hardrock ORv park Ocala,Fla.ran a few hills and bounced through some washouts,relaxing time.
The following users liked this post:
bigwill837 (06-15-2020)
#88
#93
While it would look good in my driveway, my driveway is pretty far away . Besides if my rig looked that good I would probably hardly ever wheel it because I'd be too afraid to put a scratch in it.But it is very nice and someone will be VERY happy owning it.
#95
My 1989. 37s on Stauns, Chevy 63s rear, trail gear 4" up-front, Marlin crawler, rear spool and front Detriot, 5.29s, cage and race seats. Truck was rescued from a PO who had turned it into a mall-ready monster truck with 40" tires and huge lift blocks.
#97
Staff
This is the first runner I built. It was advertised for a crawler or a parts truck.
This one was used as a part truck and I used it as a parts truck for the white 88.
This one came out of a salvage and has some parts missing. You tell a kid had it as the axle is rattle canned yellow and some other things. I wont build this one for awhile and deciding which way I want to build it.
#100
My new to me 89
December 2014 Updates, where do I start
1. Replaced power antenna with 98 Limited hardware, took some doing but it works
2. Added chrome exhaust tip, dual with resonators
3. replaced rear leaf springs
4. installed 1.5 upper ball joint lift
5. replaced both upper and lower ball joints
6. repacked front end bearings
7. replaced A/T BFG's with 33x10.5x15 mud terrains
Been a while..
8. replaced interior carpet, wouldn't start afterwards
9. Tested starter solenoid = good
removed starter, tested, passed but since it was out it was easier replacing with new
10. still nada, just wont crank over
Autozone recommended ignition switch wiring, replaced, cranked right up
(for several months it would intermittently not crank) guess that problem is fixed for a while
Tow hitch and light bar in route from Maryland
Only 2 weeks old and clutch is shot
1. Needs thorough cleaning
2. Fix AC, have all parts
3. Timing belt
and the list goes on for a long time but its gonna be fun.
1. Cleaned, Cold AC, timing belt changed, tint, Stage II clutch, new shocks, radiator, drive belts, cleaned some more, next up, replace front end parts and bushings.
2. Found out one of the previous owners disconnected speedo, coupler was finger tight (my fault for not checking before purchase) but has 138k on the 5 speed 3.0L
Been a while..
3. Timing belt
