1998 4 runner starter issue
Quick question folks:
I have a 1998 4runner SR5 V6. Recently upon start, I will turn the key and nothing happens. If I move the key back and fourth several times it usually ends up cranking just fine (but seems to be getting worse-requiring more key turns). I have heard that the connectors to the solenoid on the starter get corroded and can cause this issue.
-Can I simply clean the connections, or should I just get a new starter?
-If I need a new part, is the solenoid available as an individual part?
-Is it easier to get to the starter through the wheel well or from the bottom?
*Thanks in advance, any input is appreciated.
when you turn it over and nothing happens do you hear a click? repeated turn overs should sound like click, click, click, until it finally finds a good spot in the starter and turns over. if so its a bad connection, or more likely a bad starter. if not and there is no sound what so ever when you turn it from run to start then its likely the ignition cylinder switch that has failed. i hope this helps.
the1998sr5
10-19-2016 12:48 PM
voiddweller
19
05-02-2016 09:10 PM
B. Graves
07-03-2015 04:10 AM
