$10 Snorkel System
I just took it for a drive expecting my ears to possibly pop and it to be fairly loud. I am amazed at how quiet it actually is considering how loud the deckplate mod is. All I can hear is a light sound by the glovebox and when gunning it it lets out a small roar but overall not much louder that the deckplate in the cab. I also didn't notice any change in pressure - it must not be that airtight in the cab.
Cool, that was fast! I didn't expect someone to do this mod so quickly after I posted it. I'm really glad I did it, now I have a bit more peace of mind and no more water worries...
Hey 44Runner, your PM inbox is full.
I am considering getting a snorkel.
Anybody knows with the Taco snorkel will work on the 4Runner 3rd generation without a problem?
I see that 44runeer has one ...
I am wondering which one he got.
-JACK
http://www.safari4x4.com.au/docs/snorkel/ss170.htm
-JACK
#25
I tested out my $10 snorkel system yesterday. I was playing in some mud bogs and I found one that didn't look much different then the others. I went into it and the water was coming over my hood. I made it out with some noisy belts and a lot of crap in the brakes. I opened up my airbox and a little water got in from the top of the box. I need to come up with a better seal. The snorkel system itself didn't leak at all.
All I can say is it was the best $10 I have ever spent. My engine would be toast if I would have done it.
#31
wahoo old thread!
is abs pipe (black) supposed to be a common item at a local home depot/lowes store? i can't seem to find it and of course no one knows what i'm talking about. i would really rather get abs because it comes black instead of using ugly pvc...
anywhere else to get it?
#33
Originally Posted by garrett1478
wahoo old thread!
My $.02
#37
This is one mod that has saved my engine time and time again.....
I've driven through water that went over the hood and only got a few drops inside the airbox. Most likely through the lid on the top. Since doing this mod I've helped 3 other members, Casey, Charles and Lance with a similar designs.
The reason for ABS is mentioned in my write-up, 3" PVC won't fit the stock airbox properly.
This mod works on 4th gens, 3rd gens with stock fenders 4 cyl or V6
as for the stock antenna, there's a quick fix, by simply rotating it 180 degrees to clear. One bracket needs to be relocated.
Here's the other thread
https://www.yotatech.com/forums/f31/4th-gen-2-more-3rd-gens-internal-snorkel-installed-46043/
#38
i have now been to 3 lowes and 3 home depots around town...none of them have the abs pipe that yall use. i dont even bother asking anymore, they just lead me to this huge accordion drainage tubing. everything else is pvc...what am i missing? is it in some other random section?
#39
I've been wanting to do this with my tacoma for a while now but I have a question for you Bruce. What, if anything did you use to secure the pipe into the ~3" hole that you had to cutout? Did you just glue it to the sheetmetal? I'd like to make sure that it will never fall out...
#40
I used silicon glue to hold it in the hole I cut into the cab. As for securing the tubing, I cheated and just got a can of foam insulating and sprayed a few dabs here and there to hold it from moving. I didn't care to make it look pretty, just wanted to make sure it would never come loose. The foam is easy to remove if I need to take the pipe out in the future.....
garrett1478, I wonder if the housing code in TX don't use ABS pipe, everywhere out here has it in stock.
