Worst gas mileage the 22re has ever seen?
Old 12-21-2010, 03:40 PM
85gijunk4x4's Avatar
i got 6mpg for a while, but i never had my fuel filler cap on DUH!!
heres what i would do.
fuel filter, spark plugs, wires, distributor cap and rotor, check your timing, check for any cel's, tire pressure, clogged catilitic converter, air filter, check your gear ratio's to tire size ( if youve ever messed with your tire size or anything), 02 sensors, air flow meter, and most importantly CLEAN YOUR INTAKE MANIFOLD. the intake manifold is a common problem for toyota 22re's, the got clogged and rob plenty mpg and performance. plus you should try running something through your engine when youre done like seafoam or lucas etc.
Old 12-21-2010, 03:42 PM
Originally Posted by HaloHedgehog
I'm only 14 so I don't know much, but will shifting at such low rpms hurt the engine or tranny? Also, to anyone that knows the answer: If I put one or two turbos in a truck with a 22re, how much do you think that will bring up the mileage?
shifting at low rpm's will save your gas mileage if your not driving fast. if you shift too low though you could cause youre engine to bog and jerk wich will cause alot of wear and tear on the crankshaft, wich could lead to your crankshaft breaking. ive never seen it happen on a 22re, but it is pretty common on semi's and big diesel engine's.
as for the turbo;s though, im not too sure. and besides the 22rte, ive never seen a turbo on the 22re, and im not sure if its practical/do-able
Old 12-21-2010, 04:00 PM
vincepower's Avatar
Originally Posted by kiva
I replaced my fuel filter in my 86 22re and found it to be tough to get to, and it hasent helped my milage 1 bit.
When I did mine, I was able to undo the fuel lines but left he old one in place. I just ziptied the new one to my inner wheel well.
Old 12-21-2010, 04:10 PM
JDS1992's Avatar
By shifting at low RPMs, you can lug down your Engine pretty bad, causing more wear and tear like 85gijunk4x4 said. And how much gas is that really saving you?
And adding a turbo. wnt add to MPGs because the only time the turbo is gonna kick in is if you go Pedal to the Metal. Unless of course you had twin turbos and set one for low Rpms and one for High Rpms, but I dnt even think you can twin turbo a 22RE.
Old 12-21-2010, 04:16 PM
  #25
x2!! thats what i was thinking
Old 12-21-2010, 04:20 PM
  #26
Van Cour's Avatar
im getting 286 miles per tank in my 84 which equals out to about 17.2 . i found out the tank is really 16.6 gallons if you really run-er low haha. I have 33s 4:10s 2.22 exhaust heddman shortys and a webber oh and its bored .20 over. id say that about average. and that was with a little flooring here and there. and some slight around the corner wheeling believe it or not.
Old 12-21-2010, 04:36 PM
  #27
HaloHedgehog's Avatar
Re:
Ok, thanks for the fast reply!
Old 12-21-2010, 05:04 PM
  #28
Zelephant's Avatar
I got you all beat. I figure about 10mpg, almost all city driving (I don't use the highway much in the truck). It's actually a bit more because of the bigger tires, and its an auto, and I haven't regeared yet, and I always have ECT on. With all that considered, 10mpg is probably to be expected.
Old 12-21-2010, 07:21 PM
  #29
sebastianholmes's Avatar
its not whether or not you CAN TT a 22RE, its WHY IN THE HELL would you want to? its supposed to be reliable, not go 100+ mph. if you want somethign like that swap a v8 or a 4.3 chevy and SC it
Old 12-23-2010, 05:30 PM
  #30
Re:
Funny you would say that haha. I was kind of hoping to make it go 100, my friend is going to get a Supra so I was hoping I could ride around with him and at least keep up to him without spending all my money on gas.
Old 12-23-2010, 06:13 PM
  #31
Ok, thanks!
Old 12-24-2010, 09:06 AM
  #32
Just read another thread on here that said it would cost more to get it faster via twin turbo than just swapping engines. Thanks for all you're help everybody!
Old 12-24-2010, 02:16 PM
  #33
yotergirl1993's Avatar
ur lucky with what ur pullin outta ur 4-runner. i only pulled 11 on a good day! 9 regular!!! i done everything i could thing of... tune up new fuel filter, cut the converter off... still no good. but i also had the main bearings going out.
Old 12-24-2010, 04:57 PM
  #34
peow130's Avatar
LOOOOL.
yeah good luck getting your 100HP engine to go 100mph.
most of us cant break 70 stock, while going downhill, with a tailwind.
a supra will destroy a 22r powered truck.
not only that, but twin turbos definitely arent applicable on anything under 6 cylinders.
if you want to go fast, go get a Vtech honda, turbo it, get a header and exhaust, and have fun.
Old 01-02-2011, 12:03 PM
  #35
Re:
Originally Posted by peow130
LOOOOL.
I kind of need to go somewhat fast, I will be in the Fire Department, and will have to respond to calls. I'll look into other options.
Old 11-04-2011, 10:29 PM
  #36
Camo2294's Avatar
Before I lifted my 86 2wd 22re I was easily able to hit 100. I would easily cruise on the tpike going 80 and with 6 1/2 lift and my new 33's and stock gears, I still have descent pickup in fifth. Also the truck is a factory one ton
Old 11-05-2011, 10:39 AM
  #37
CTRJ's Avatar
I don't think there is a fire truck that can go 100 mph. They hardly go over the speed limit. My guess is if you are not riding out on the truck, you're probably not essential enough to need to break the sound barrier to get to a call.
Driving 100 is irresponsible and stupid. You put yourself and others at risk when you drive like that.
Old 11-05-2011, 03:26 PM
  #38
Camo2294's Avatar
I was on a 2 lane highway with no traffic in the middle of nowhere, everyone likes to experiment sometimes
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
pyramid
07-30-2015 10:05 AM
daddio
07-18-2015 10:20 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: Worst gas mileage the 22re has ever seen?
