Will a Camry knock sensor work in 3vz pickup?
Old 06-30-2013, 01:36 PM
iamwieb's Avatar
Tearing this bad boy down and running low on cash flow. Need to replace the knock sensor ( whole plastic connector melted off the top) have a new wire in the mail but don't wanna spend 140$ on new knock sensor if I can put a differently " labeled" part will work. Like a camry one? Also want to insulate the wire or any other part of this sensor to corrode, how do I do this?
So far I've got new water pump/ timing belt and tensioner to go on, a new oil pump coming in mail, injectors off for cleaning, and new rear seal to go on too. Spent a lot on this and trying to get out alive.
Heads at machine shop, timing and new valves an ˟˟˟˟. Complete gasket set from engnbldr in the mail plus head bolts.
Also ( with correct installation) how long will this motor last b4 it ( the motor) needs more work?
Thanks yotatekkers for any advise. And all the great write ups that gave me confidence to do this job.
voiddweller
19
05-02-2016 09:10 PM
91toybeater
12-27-2015 07:46 PM
gog1968
06-22-2015 05:55 AM
bobbybouche
06-18-2015 10:22 AM
duckhead
3.4 Swaps
7
06-18-2015 06:54 AM
Quick Reply: Will a Camry knock sensor work in 3vz pickup?
