Why 21 or 23 spline? I don't get it? 4.70 T-Case Gears
Old 06-10-2011, 06:15 PM
TinkerAB's Avatar
please help a newbie out.
Please tell me or link me information regarding where 23 spline would apply and where 21 spline would apply. I see trail-Gear offers both. THanks in advance.
Old 06-10-2011, 07:17 PM
bigarms23's Avatar
23 spline is usually stronger than 21 and came in 87-88 gear driven transfer cases and 21 usually came in 79-85 but if your ordering 4.7 gear go with 23 splines
Old 06-10-2011, 07:43 PM
TinkerAB's Avatar
I am just confused what spline count is made for which transfer case. I have a 93 4Runner V6 manual with stock transfer case. Can all of these transfer cases use 21 or 23? Will other things need to change with different splines? Thanks
Old 06-10-2011, 08:55 PM
Peterbuilt84's Avatar
I think v6's came with chain driven cases, which will not work for the 4.7 gears. You would need to get a v6 to gear driven case adapter. Then get the 4.7 gears for the gear-driven case. I think trail gear sells the adapter too, if you want to go that route.
Hope this helps.
Old 06-11-2011, 06:31 PM
bigarms23's Avatar
you have a chain driven tcase so you will need the adaptor and a gear driven tcase
smthwsn357
05-01-2024 07:28 AM
mskalmus
05-28-2017 07:51 AM
razorman8669
07-12-2015 12:13 PM
icentropy
07-11-2015 07:21 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Why 21 or 23 spline? I don't get it? 4.70 T-Case Gears
