whining sound
whining sound
Hi i have a 87 toyota 4runner 22re and im getting a whining sound around the engine, i cant seem to narrow it down exactly but when i give it rpm it's pitch increases. The only thing i can think of is mabye a bearing, say water pump or cam shaft or crank shaft or seomthing, any ideas??
cheers
dave
cheers
dave
Power steering pump? Loose pully belts? Check your fluids?
Something my be just vibrating but check these things.
__________________________________________________ _
95 Toyota 4runner SR5 V6 3.0 4X4 Automatic 150,000 Miles
You didn't state whether the whine occurs out of gear or rolling, under power, in gear. If it only whines while in gear and rolling see if the whine goes away in 4th gear...if so refocus your attention to the tranny.
zytra
01-24-2019 03:16 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
