where is my o2 sensor wire in a 86 4runner
The 86 4runner my o2 sensor is in the manifold mine melted off where do you find the single wire that runs to the 02 sensor in the manifold, witch area of the body or wire harness?
I went out and took a picture of the 02 sensor wire on my 86 4Runner, if you look at the master cylinder there are two wires that go to it for the fluid level sensor, the wire for the 02 sensor comes out in that same harness, its a gray wire with a white plug on the end of it.
steve miller
10-10-2015 01:40 AM
