What Weber carb will replace a stock '85 carb?
Old 05-01-2010, 06:01 AM
mldave's Avatar
What Weber carb will replace the factory carb on a stock 1985 22R?About what price and how long to change it?....thanks.
Old 05-01-2010, 09:22 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
You'll get more power, but if you don't know how to set it up, it will take you a while...
There is nothing wrong with an ASIN... IMO, you'll be a lot better off. And you won't be searching for how to plug all those vac lines...
Read the links in the 1st post.
http://forum.ih8mud.com/79-95-toyota...ad-bypass.html
Old 05-01-2010, 09:24 AM
If you have emissions where you are, I'd avoid it (the Weber) like the plague though...
Old 05-01-2010, 10:52 AM
mldave's Avatar
Yes this is Kalifornia..plenty of emmisions.....thanks.
Old 05-03-2010, 11:51 AM
thebrick's Avatar
the weber 32/36 is the replacement. they are smog legal in CA according to the CARB website, but your local smogger may not know this. They are 400ish dollars, and the kit should be a direct swap to your truck.
depending on who you ask they may or maynot be worth it. some people love them, others have problems. you may be surprised at the improvement from simply rebuilding your current carb. I would definetly try rebuilding before buying the weber, as rebuild kits sell for 40 bucks(i just did this, they aren't to hard to clean and rebuild). if you are looking for more power try a header, the 20r/22r/22re responds well to them.
mskalmus
05-28-2017 07:51 AM
lledwod
08-30-2016 01:03 PM
Yota.Jay
07-23-2015 08:08 PM
TURBOrunnerNM
07-22-2015 11:01 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: What Weber carb will replace a stock '85 carb?
