What are the weak spots on a 1989 4x4 Pickup?
Old 11-03-2013, 04:35 PM
jpluddite's Avatar
Hi guys.
In another thread I asked about the transmission of my 1989 toyota 4x4 pickup. It turns out that the tranny needs to be rebuilt or replaced, but before I do either, are there any particular weaknesses on this model truck that I should pay special attention to? It's due for inspection, so I'll ask the mechanic to carefully go over any trouble areas that you guys suggest.
The body and frame are in great shape--amazing actually for the age. But I don't want to dump good money after bad, if there are other likely problems.
So, I'll appreciate any tips you have for what I should pay special attention to.
Thanks guys.
Old 11-03-2013, 04:44 PM
totally a bro
Staff
vital22re's Avatar
auto or 5spd? 4cyl or v6?
Old 11-03-2013, 06:10 PM
jpluddite's Avatar
The truck is a 4 cylinder 22RE, 5 speed manual.
Old 11-03-2013, 06:52 PM
old fart's Avatar
About 85-90% of the people on the site will tell you the 22re is a great lil motor. So is the 5spd when in good shape. You said the frame and body was in good shape, so that's one weakness answered, the body above the tires and the cab panels usually suffer from rust. Other than that, if the truck was taken care of ok, I can't seem to think of anything else to comment.
Old 11-03-2013, 07:06 PM
85toy4runner's Avatar
yeah , the 22re together with the 5speed is the one to be desired
Old 11-03-2013, 07:16 PM
dsal_86Yota's Avatar
lower part of fender wells and beds are weak points for rust. Where the truck from? If the area gets snow and uses salt, check for rust on bed. Im on my 2nd bed on my truck cause of rust and Im in colorado, no salt for ice roads here
Old 11-03-2013, 10:40 PM
wyoming9's Avatar
Red face
Unless this truck has been restored or rebuilt all ready or the last owner moved up from the Southwest USA
That would be the only way it is in as good of shape as you say or think.
look at the fuel and Brake lines
If the transmission is coming out time for a new clutch and the hydraulics .
Some people take care of things others just run them into the ground who knows just what is the story in your case.
These are good Trucks but normal maintenance needs to be done.
Brakes in good shape
Driveline u-joints wheel bearings Hubs things like that all working
You just need to take it one day at a time.
Is this a long term project or your only transportation
i am not that far away if you get stuck
Old 11-04-2013, 02:48 AM
jpluddite's Avatar
I attached some pics of it
Attached Thumbnails What are the weak spots on a 1989 4x4 Pickup?-bed.jpg   What are the weak spots on a 1989 4x4 Pickup?-back.jpg   What are the weak spots on a 1989 4x4 Pickup?-passenger-side.jpg
Old 11-04-2013, 02:54 AM
jpluddite's Avatar
Here are a couple more. If there's interest, I have pictures of the under-carriage.
Attached Thumbnails What are the weak spots on a 1989 4x4 Pickup?-driver-side.jpg   What are the weak spots on a 1989 4x4 Pickup?-front.jpg
Old 11-04-2013, 12:53 PM
that looks like a nice truck , I like that, and its got the 22re and 5speed , those sell fast with that combo
Old 11-11-2013, 09:03 AM
kirkerik's Avatar
Nice color.
Some rustproofing like FluidFilm is a good option. Especially inside body panels and the frame. Cover any rust with a rustconverter or rust primer and paint before rustproofing
kirk
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-06-2015 12:17 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
zd92655
07-05-2015 04:25 PM
Quick Reply: What are the weak spots on a 1989 4x4 Pickup?
