what is this coolant system part? I need a new one.
Hi all -
I've been browsing the forums here for a while and have realized that this site is an AWESOME resource. Now unfortunately I have a problem and hope I can get some help. So here goes my first post:
My '93 pickup with a 22RE engine has some problems. When I last drove it, I noticed A. the idle speed was erratic - surging at times. B. there was a coolant leak coming from a hose connection.
When I unclamped the hose to remove it, a small elbow type piece that it was attached to came loose from its threads somewhere on the bottom of the block.
This elbow piece is totally corroded. I will need to replace it, but i'm not sure how to find one as I don't know what the part is called. I've attached pictures.
Can anyone identify the part?
THANKS!
THANKS!
That was very helpful! The part is 16261A. I happen to work across the street from a huge auto parts wholesaler that sells direct to auto shops. They were able to order it from Toyota for me. Should be in tomorrow. I was able to get most of the damaged part out from the block as far as I can see. Hopefully the new one threads right in.
Thanks for that schematic.
Whoops, I mean 16261B. Nice catch. I know I didn't order a clamp because it was twenty bucks.
I took a pic from under the engine bay, looking up. An arrow is pointing at the the threaded hole where this piece came from.
Anyone know what this part is? I'm looking around online but haven't found anything.
Also please note the image is upsidedown.
I'm planning on flushing the coolant and installing some new hoses.
Any suggestion on hose type? Is it worth it to run silicone hoses on a truck with 220,000 miles?
Truck has a few new hoses and all new coolant / distilled water - running like a champ. Thanks all for the help.
Next project is to replace the thermostat.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
Vargntucson
07-04-2015 12:15 PM
