What is this? Brake booster connection
Old 02-21-2011, 04:13 PM
dnbuggy's Avatar
What is the tube in the circled area for? It is located right below the carb. I just got an 87 suzuki samurai conversion with an 87 22r carburated motor and the engine ran like crap until I capped this port. It was just wide open. What is it for? Is it okay to just cap it or do I need it to do something else?
Old 02-21-2011, 04:16 PM
xxxtreme22r's Avatar
old place where the toyota brake booster hose would go.
Old 02-21-2011, 04:27 PM
peow130's Avatar
If the sammy has a brake booster vac line, run it to that port.
You might consider doing the toy MC swap into the sammy, if you're doing the toyota axle swap
Old 02-21-2011, 05:04 PM
dnbuggy's Avatar
The sammy has toyota axles already and a Toy MC. Where exactly does this go? Straight to the MC? Is it bad if I just cap it?
Old 02-21-2011, 05:06 PM
to a 1 way check valve and then to the booster. As long as your power brakes are working and your cap isn't leaking it's fine to cap that off.
Old 02-22-2011, 09:45 PM
peow130's Avatar
Pics?
I'm a sucker for a built up sammy.
justdifferentials
Just Differentials
09-17-2015 06:14 PM
corey519
08-12-2015 11:12 AM
accuracy
08-04-2015 08:05 PM
CanRunner
07-20-2015 01:29 PM
87turboPA
07-12-2015 07:49 AM
Quick Reply: What is this? Brake booster connection
