Vibration @ 65 mph w/ driveshaft taken “OFF"
Vibration coming on at 65 mph with the drive shaft “OFF”.. When drive shaft is “ON”, vibrations is at 25-40 and 60-70 mph..
Issue occured after a lift with TG 5”. First install was done incorrectly and I busted the CV double cardan joint. I had a shop balance and install a new shaft and check the U-Joints.. After the new rebuilt shaft the vibration was reduce by 80%. I took off the rear drive shaft and put that in gear all the way to 65mph where I felt a slight vibe. There it was pretty consistent. I need to know what can cause that vibration??
86 T4R SAS / Duals
My current measurements:
39” long Driveline / dual cases
TC = 5*
Shaft = 18*
Pinion = 17*
86 T4R SAS / Duals
TC = 5*
Shaft = 18*
Pinion = 17*
checked!! and checked!! vibrations seems to occur when i accelerate or steady on gas at that speed. Right with I let foot off gas. its smooth and quite.
trailgoat
08-13-2015 05:54 PM
Tonetrk
08-06-2015 10:06 AM
