Valve Lash
Old 11-09-2007, 08:10 PM
rowdy235's Avatar
Valve Lash
Okay, so as many of you know my truck has low compression on one cylinder.
A friend of mine did something or other and told me it doesen't seem like #3 exhaust valve is closing. He said it was probably a lash issue, and that I should adjust it. I am planning to do this tomorrow. I have a few questions:
1. Any tips for this job?
2. What bad things can come from repairing this issue, if any?
Old 11-14-2007, 07:22 PM
colsoncj's Avatar
Tips: Do it when the engine is warm, and check it a couple of times if you havent done it before to make sure.
Bad things: too tight and you could get bleed by, lowering compression and burning up the valves. too loose and you get chatter and poor performance.
Good things: if its off, better performance, longer valvetrain life, better compression (depending on which way its off)!
Dont worry its not a super difficult job!
Old 11-14-2007, 08:18 PM
SCYOTA's Avatar
Maybe I am misunderstanding you but have you ever adjusted the valves on a vehicle before? Like colsoncj said, make sure your engine is at normal operating temp before you adjust them. It is pretty simple really. If you actually need help adjusting them let us know. If you don't already have a repair manual you should go get one. It will be able to walk you through the entire procedure.
Old 11-14-2007, 08:21 PM
rowdy235's Avatar
Yes I have a repair manual but I was just checking to make sure that there were no special tricks involved. I have done valve lash, just never on an OHC. So I reckon this weekend I'll give it a whirl. Lets hope the compression goes up!
Oh and PS- the engine was rebuilt around 30k ago so I am due for an adjustment anyway.
colsoncj's Avatar
agreed...
EDIT: posted before I did! Well let us know if ya need anything!
Old 11-14-2007, 08:37 PM
surf4runner's Avatar
Originally Posted by colsoncj
Do it when the engine is worn...
thats not 'worn' enough
if they havent been adjusted since the rebuild, its past time to do it.
Old 11-14-2007, 09:35 PM
rowdy235's Avatar
judging by the actions of the PO, it probably never was.......
Old 11-15-2007, 06:08 AM
colsoncj's Avatar
oops.. i swore i wrote warm... oh well, I'll edit it.
LotOMiles
09-14-2015 11:45 PM
ac7822
09-11-2015 08:49 AM
Streetrod19772000
09-10-2015 06:22 PM
Boomer8404
09-10-2015 09:01 AM
idadan208
09-07-2015 09:06 AM
Quick Reply: Valve Lash
