Upper ball joint hitting coil spring
Old 02-23-2014, 05:42 PM
YoDaddy1's Avatar
Hi all, a noob here, just purchased a 97 Tacoma 4x4, took it to tire shop to get 35s balanced, when up in the air, I noticed that the upper ball joint is hitting the coil spring when suspension is fully extended. Truck has a 2" spacer above the coil and a 3" body lift running 35" tires..
Any ideas would be helpful, thanks
09-04-2015 09:27 AM
krimsonone
07-29-2015 11:53 AM
coffey50
07-28-2015 10:55 AM
Massmayhem247
07-24-2015 12:07 PM
ksmudrunner99
07-21-2015 05:33 AM
Quick Reply: Upper ball joint hitting coil spring
