Old 03-30-2016, 03:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Transmission Guides
Print Wikipost
Toyota Pickup Transmission care
Old 03-23-2012, 11:09 AM
Jasper 83's Avatar
Whew i would be careful with an impact on aluminum. Im not tryinto be smart ass but are u sure you are turning the right way? I like to ise the 2 wrench method when i cant get somethin lose or a 1/2 inch breaker bar
Old 03-23-2012, 02:39 PM
MudHippy's Avatar
The fill/drain plugs aren't aluminum. So if you want to use an impact driver to remove one, that's fine.
Old 03-23-2012, 03:15 PM
Jasper 83's Avatar
What they're threaded into is
Old 03-23-2012, 06:30 PM
MudHippy's Avatar
And you're going to damage the aluminum by using an impact driver to remove the fill/drain plug how exactly?
Maybe the 2 wrench method would be safer though...
Old 03-24-2012, 12:42 AM
  #25
Jasper 83's Avatar
All it would take is to accidentally have the switch turned the wrong way.
Old 03-24-2012, 03:12 AM
  #26
rjfortuna's Avatar
Oh, I agree. I see the inherent danger of impact around aluminum. But that thing wouldnt budge. I even looked it up in my book to make sure I was on the right nut n such, and checked it twice. But anyway... Thanks for the input. I'll figure something out.
Old 03-24-2012, 04:52 AM
  #27
Jasper 83's Avatar
All the ones ive ever pulled out have been tight. I cant beieve the impact wouldnt get it out. Thats crazy tight. Apparently the one on my 4runner is or was tight at some point cuz somebody rounded it off beyond recognition. Im glad toyota hasnt discontinued parts like american car manufacturers. I wasnt sayin dont use an impact on aluminum but definitely excercise extreme caution. You know how sometimes youll hit the switch by accident without realizing it and then bad things happen. Good luck gettin it out
Old 03-25-2012, 03:24 AM
  #28
rjfortuna's Avatar
Crazy tight for sure. Extreme caution for sure. I'm kind of stuck on this one. Dunno for sure what I'm gonna do. I....Dunno. I was perplexed for sure. I figured i would just...you know....tap it with the impact, it would break free but....Nope.
Old 04-06-2012, 03:09 PM
  #29
Rogueaire's Avatar
Originally Posted by 86toysr5
make sure you take the fill plug out first to make sure it will come off....it'd suck to take the drain plug out and not get the fill plug out...... rowdy all you gotta do for that is to take boot off and the 4 bolts and pull the shifter out
Does this discussion of a 1994 toyota pickup transmission oil change also apply to a 1989 Toyota Tacoma pickup 5 speed?
Old 04-06-2012, 04:16 PM
  #30
RAD4Runner's Avatar
Smile
Originally Posted by wyoming9
Well even in 2wd the transfer case is turning.
Did you check the front differential as this only turns when the hubs are in.
It is a sad fact that people often just drive these vehicles with no maintenance what so ever .
Bearings that run dry on oil only last so long.
It could just be the front differential is just noisy from being worn.
Guys, you might want to note that the manual recommends that we drive in 4WD for at least 10 km per month in order to keep the front differential seals lubricated. Else they could dry up and crack. It makes sense. I think P.O. of my 86 Runner did not do a whole lot of 4W-Driving, that as soon as I tried 4WD, I saw some leaks around my front axle.
Any problem with that? Any problem with the doc saying that wine is good for you?
Old 01-03-2013, 03:29 PM
  #31
Originally Posted by yukon6inchlift
hey, just checked ur amsoil site this is what it said for a 81 toy pickup;
Manual Transmission, 4-SPD..........4.0 pints
Manual Transmission, 5-SPD..........5.5 pints
shouldnt that be quarts???
R150 shows ........Manual Transmission, R SER..........6.3 pintsTransfer Case, W/ MT..........2.3 pints
got to be a typo !
Old 01-24-2013, 11:42 AM
  #32
christoph8_21's Avatar
I just drained mine and re did the fluid. Awful experience. Not technically hard, just that the gear oil is the grossest substance ever.
Old 05-12-2014, 05:16 PM
  #33
Latínyota's Avatar
I need a tránny 4x4 for 22re
Old 09-24-2016, 03:46 PM
  #34
Njonas126's Avatar
Ok to use redline 75w90 in transmission?
im reading the back of the bottle of redline 75w90 full synthetic gear oil and it says "not for use in most manual transmissions with synchronizers" I saw an above post that said this is the best thing to use. And one have anything to add?
Old 09-24-2016, 05:21 PM
  #35
millball's Avatar
Old trannys like straight GL-4 spec oils, not GL-5 spec, or GL-4-GL5 multispec oils.
The GL-5 oils often prove too slippery to permit good syncro function.
GL-5 oils, on the other hand, are perfectly fine for differentials and transfer cases.
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
zytra
06-24-2015 08:14 AM
Quick Reply: Toyota Pickup Transmission care
