timing chain cover stuck
Old 04-18-2011, 02:41 PM
deano1982's Avatar
What is the fsm and where do i go to see it? I was also looking for torque specs for the cover and everything else.
Deano.
Old 04-18-2011, 02:48 PM
xxxtreme22r's Avatar
FSM: right click and save as, it's a big file.
not sure which one you need though.
93 Pickup http://www.ncttora.com/fsm/1993/1993.zip
90-95 4runner http://www.ncttora.com/fsm/1990-1995....1990.1995.zip
Old 04-18-2011, 05:55 PM
peow130's Avatar
Eff that.
We loaded RTV on both sides of every gasket on my timing cover, except the top.
Havent had a single issue yet, and i guarantee it's held on better than with just a paper gasket.
Old 04-18-2011, 06:02 PM
I don't know about you or the O.P. but my rock timing set came with a silicone gasket as opposed to a paper one. I think I remember using a very very thin coat of RTV on the timing cover gasket just enough to hold it in place now that I think about it.
Old 04-18-2011, 06:12 PM
  #25
peow130's Avatar
Idk what mine was, but i know i ripped the first one, and the second didnt seal worth crap.
the 3rd and most recent time with the head off has yielded NO leaks whatsoever.
Old 04-18-2011, 06:17 PM
  #26
Mine doesn't leak either. Now the oil pan gasket is another story. Stupid me put the dang pan gasket that came in the kit on along with some rtv and well......
Old 04-18-2011, 06:23 PM
  #27
deano1982's Avatar
You guys are awesome! Thank you so much for your help Bros.
  #28
peow130's Avatar
lol.
when i pulled my head, we found a copper shim, i forgot about that.
fyi, if you're doing the tchain, check for any shims. they get bent pretty easily.
Old 06-29-2011, 08:23 AM
  #29
86bedlesstoy's Avatar
hit it with a hammer on the coolant hose arm. And pull it till you start seeing coolant and oil..
Old 04-21-2017, 10:13 PM
  #30
Micah Day's Avatar
22RE engine is a non interference motor
I didn't take head off nor oil pan. Took all bolts out, but left in holes to not get mixed up. I took a 2x4 and tapped to get it loose and it just fell out for me. My question is the bolt that's under the distributor in front of the head. It's stripped. Can I retap it and put a bigger bolt in its place as long as it's the same length and not much bigger than what the stock is? Everything in my 85 22RE engine is new but piston and rings.
06-01-2021 01:51 PM
msane99
07-11-2015 08:08 PM
ItsJustD
07-07-2015 07:49 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: timing chain cover stuck
