Timing 89 22re comp cam
Old 06-08-2010, 10:10 AM
nitro4runnin's Avatar
Hey guys, just a quick question! Just had engine rebuilt , 89 22re 5 speed , complete overhaul. I installed the comp 252 cam in the process, per comp.. I set the vfm 1 click counter clockwise and added some advance to timing. The 22re in this 4runner likes about 30* btdc with no pinging! Does that seem like alot of timing considering the cam? What gives?
Old 06-08-2010, 02:44 PM
Anybody have any ideas? I'm thinking cam timing! But I know that you run some advance with that cam and I checked tps!
Old 06-08-2010, 03:20 PM
snobdds's Avatar
30* is more than double the reccommended specs. I have no first hand knowledge about changing the AFM (its AFM not VFM), but I know most people run 268 & 261* cams with no adjustment to the AFM.
I think you have some bigger issues going on here. When you changed cams, did you just do that or did you do some other engine work too?
Old 06-08-2010, 03:25 PM
Nope just the cam! It was suggested by machine shop! Called comp and they said the smallest cam they make will work with efi! I just wanted a nice running little rig. Shoot it barley hits 65 mph! I have read and read only thing I can come up with is cam timing!
Old 06-08-2010, 03:27 PM
O an I rebuilt engine an head , no other perfomce mod in th engine it's self. Have header manaflo cat but that's it!
Old 06-08-2010, 04:03 PM
Not at the moment, I will when I get home! Do you think tps could cause this type of condition? I can adjust timing all the way in and out and it holds!!
Old 06-08-2010, 04:32 PM
Well that's what I feared. I will did into the cam timing and check it out . Thanx for the help!
Old 06-08-2010, 04:50 PM
I know what u mean. I picked it up today from them, second time they had it. First time they put a cam that was to big , and it ran like s::t. So I had them swap it to the smaller one and now this. Got home timing set at 24* an it was sluggish. I knew then something didn't jive. I played with it got it to 30* and it started to run good. This blows, who has time to go back an forth dealing with stupidity! I'm done with these guys!
Old 06-08-2010, 05:10 PM
That being said! so cam timing being off wouldn't cause u to run more advance to compensate?
Old 06-08-2010, 06:04 PM
10-4 thanx I will get on it ! Appreciate the help bud!
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Timing 89 22re comp cam
