They say go BIG or stay home
Old 04-25-2011, 07:56 AM
1993jumper's Avatar
Cool They say go BIG or stay home
Gotta go. my new 22RE is not right Im tired of messing with it. So a small block chevy 400 is in the works anyone have any experience with these swaps? what all is entailed with this. This is going into my 93 2wd truck. any advice would be very helpfull. Thanks Jim.
Old 04-25-2011, 08:50 AM
WHEELER8688's Avatar
your definatly going big with that 400, go to the engine swap section and you can find info for these swaps
Old 04-25-2011, 08:56 AM
1993jumper's Avatar
BIG is better 2.4L to 6.6 gonna be a ride!!
Old 04-25-2011, 09:07 AM
Fink's Avatar
Moved to the Newbie Tech Section.
As WHEELER said, do a search and narrow it down to the Engine Swaps section and you should find a ton of info about various domestic swaps.
Fink
Old 04-25-2011, 09:10 AM
blake.nemitz's Avatar
i would use that motor with a chebby 2wd tranny like a th350 or something like that to make it easy.
xxxtreme22r's Avatar
IMO that 400 even in stock form is gonna be way too much for that 7.5" rear end. Can't say about the trans though. If auto I would lean towards definitely not. Manual mayyybeeee.
Old 04-25-2011, 09:12 AM
1993jumper's Avatar
yea manual 5 speed my main concern is holding the weight in the front.
Old 04-25-2011, 09:24 AM
Alberta4x's Avatar
Heavier springs in the front and you shouldn't have too many problems holding the weight of the motor.
Old 04-25-2011, 10:36 AM
1993jumper's Avatar
Talking This is what I have to work with
Has a duel shock system. What new bars or coil overs
Old 04-25-2011, 11:26 AM
Alberta4x's Avatar
If you're sticking with torsion bars, I'd get 26mm bars, with the weight of the motor they should ride nice and soft.
Old 04-26-2011, 07:42 AM
1993jumper's Avatar
Pulled the 400 this morning
Old 04-26-2011, 07:57 AM
I would at least get a racing clutch for your trans, if not then run a trans that was meant for that engine. I doubt even the HD marlin clutch will hold it for very long. Will probably be a little cheaper going with a GM trans as well.
Old 04-26-2011, 08:01 AM
Fossilized
Staff
dropzone's Avatar
why are your shocks Fighting??
you have dual shocks
Old 04-26-2011, 08:11 AM
1993jumper's Avatar
13" travel in the front 2" body lift.
Old 04-30-2011, 06:50 AM
1993jumper's Avatar
Heads are done its time to reassemble.
Old 04-30-2011, 08:25 AM
wii_tarded's Avatar
Old 04-30-2011, 09:22 AM
Sponsor
Tofer's Avatar
Old 04-30-2011, 10:02 AM
4x4climber's Avatar
what they said ^^^
Old 04-30-2011, 10:37 AM
1993jumper's Avatar
Talking
You got it TOYOTA
Old 04-30-2011, 11:26 AM
warpigg's Avatar
she looks purtty what are you gonna do for engine mounts?
Quick Reply: They say go BIG or stay home
