Swapping ADD to Manual hubs?
Old 04-08-2011, 10:04 AM
Alberta4x's Avatar
Old 04-08-2011, 11:26 AM
Crites_Seth's Avatar
awesome. That's exactly what I was wanting to do. Seems so ridiculous to be turning all that stuff on the pavement. Thanks!
Old 04-10-2011, 04:50 PM
yotaluver's Avatar
is this info true on a 03 taco as well... I always thought I had to swap the shafts or some crap like that???
Old 04-10-2011, 04:52 PM
4Crawler's Avatar
Yep, more work involved on the Tacoma pickups and 3rd gen 4Runners. Search for some write-ups.
Old 04-10-2011, 05:06 PM
  #25
yotaluver's Avatar
yeah thats what i thougt, I decided it wasn't worth it long ago but than ran across this and just wanted to make sure...
Old 07-26-2018, 02:57 PM
  #26
Ryryalberto's Avatar
Originally Posted by 4Crawler
Just swap the hubs and you can leave the rest of the ADD stuff as-is. The hose clamp mod. is to lock the ADD actuator full time. But if you are having no issues with the ADD and simply want to unlock the hubs for most of the time, manual hubs will do that. Then, when you may want to use 4WD, lock the hubs, then your normal shift-on-the-fly 4WD mode will work just like it does now.
Can I still use 4lo though? I want 2wd, 4lo and 4hi and I want to do the conversion. But was wondering if I'd lose 4lo by doing it.
Old 07-26-2018, 03:07 PM
  #27
4Crawler's Avatar
Sure, no problem there. In fact you can even have a bonus gear. With the hubs unlocked and the case in 4L to you have 2L, lock the hubs and you have 4L. With the stock ADD setup, it's like you have permanently locked front hubs (i.e. the drive flanges). If you swap to manual hubs and leave them locked all the time, you've made no change in the system, it works exactly the same as before.
The following users liked this post:
Roman255 (02-28-2023)
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
oldirtydirt
02-23-2020 09:30 AM
deepmarsh
08-06-2015 03:44 AM
Steven.m.paulk
07-13-2015 01:40 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Swapping ADD to Manual hubs?
