Spark plug and wires recommendation
Old 10-20-2010, 07:28 PM
Skinamer's Avatar
What brand plugs and wires do you recommend for a 22RE? Denso, NGK, other?
I want the best I can buy that has EXCELLENT emi/ noise suppression.
Old 10-20-2010, 07:44 PM
iamsuperbleeder's Avatar
NGK for both, a thousand times over
Old 10-20-2010, 08:08 PM
Skinamer's Avatar
Is it worth the extra buck to get the iradium plugs?
Old 10-20-2010, 08:11 PM
AmpedRunner's Avatar
I would say bosch twin platinums myself they worked really well for me and seem to be lasting
Old 10-20-2010, 08:22 PM
SoCal's Avatar
Toyota needs NGK. Even a Toyota tech will tell you NGK is the only thing if you want it to run as designed.
Old 10-20-2010, 08:23 PM
Elton's Avatar
really now toyota's only like ngk or denso
Old 10-20-2010, 08:30 PM
Idk man they work really well in mine, after I put them in I even got water vapor out the tail pipe from complete combustion. maybe my runner is weird
Old 10-21-2010, 12:46 AM
wyoming9's Avatar
Red face
I just use the Toyota wires and plugs anymore.
I had so many problems with the after market wires I switched to Toyota wires and the problems went away.
The price is on par with a good set of after market wires.
Old 10-21-2010, 04:07 AM
pruney81's Avatar
NGK plugs and wires. No need to get anything more than that. They can be found at most auto parts stores.
Old 10-21-2010, 02:31 PM
hamish_18's Avatar
to put in my 2 cents... I have a 93 v6 pickup. I had the napa lifetime warranty wires, and Bosch+4 plugs. I was having weird mis fire conditions, and a huge hesitation at lower rpms. I took it to multiple mechanics who never could figure it out. So I finally snapped and took it to the toyota dealer. The mechanic instantly started taking my plugs out and replaced them with stock ngk's and new toyota wires. He went with me for a test drive, and explained that he has seen this for years now. My truck has never ran better since. I will never buy anything but toyota stuff now. It just works.
Old 10-21-2010, 04:03 PM
Skinamer's Avatar
Does Toyota use NGK wires too or just plugs?
Anyone have any experience with the new NGK Iradium Plugs?
http://www.ngksparkplugs.com/product...x.asp?mode=nml
Old 10-21-2010, 05:09 PM
DethYota's Avatar
Try to use the V-Power NGK plugs in our old tired engines if you can. The Iridiums will burn too hot for our engines (Unless you have done other modifications).
I Put in V-Power NGK Plugs Part #1233 and BWD Select Wires #CH5414
This is for my Gas Powered 22re btw
Old 03-28-2013, 01:39 PM
-City Slicker's Avatar
similar question.
my truck has 138K
with a battery intake swap
& a 2.25 inch exhaust
im going with NGK:
but should I go V-power or iridium
should I look at the current plugs to find out..?
raptor510
02-17-2017 07:11 AM
Alex Bessinger
08-31-2015 09:17 AM
cars-guy
07-11-2015 07:51 PM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: Spark plug and wires recommendation
