Shock Absorber Kidney Failure
Old 05-14-2008, 04:43 PM
mvsbraga's Avatar
I have a 1990 2dr 4Runner/V6/5 sp trans. I just installed upgrade torsion bars and 1-1/2" lift HD rear springs from Downey Toyota. I also installed KYB Mono Max shock absorbers and 33 x 15 x 10.5 All Terrain KO. The 4runner now rides like a one ton. I like a stiff vehicle, but this bounces and you're air born even going over speed bumps at a slow speed.
Downey recommends the Doetsch shocks and I went with the KYB's because I wanted a mono shock. Do you think the Doetsch would be the better way to go? Are Doetsch that much softer? Since I now have a 1-1/2" lift, the number of available shock absorbers are limited and I really don't want to use a shock mount extension.
Does anyone have experience with both of these shocks?
Thanks for your help.
Old 05-16-2008, 04:54 PM
FredTJ's Avatar
While softer shocks will most certainly help, you've got to remember that you've also installed quite a bit stiff springs, front and rear.
Fred
Old 07-31-2010, 02:52 AM
kurtdaniel's Avatar
I have a 1990 2dr 4Runner/V6/5 sp trans. I just installed upgrade torsion bars and 1-1/2" lift HD rear springs from Downey Toyota. I also installed KYB Mono Max shock absorber and 33 x 15 x 10.5 All Terrain KO. The 4runner now rides like a one ton. I like a stiff vehicle, but this bounces and you're air born even going over speed bumps at a slow speed.
I will not say a single negative thing about other lift/shock manufactures/suppliers. but Doetsch has poured more time into the car suspension and service then any others by far.
ladybugRC
458
08-21-2020 10:41 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Shock Absorber Kidney Failure
