Replacing head gaskets on a 1995 4runner sr5 3vze
Old 08-25-2011, 03:16 PM
SnowDrive215's Avatar
Talking Replacing head gaskets on a 1995 4runner sr5 3vze
Hello! My names Andrew, I'm new to YT and diggin this forum. I am going to be replacing the head gaskets to my 1995 3VZE with 160k on it. I have never worked on a toyota but am a decent mechanic. I know I will need some help so I will be posting updates and photos of my work for some feedback.
I also have an automatic tranny issue...it doesnt shift on its own. It worked fine when i bought it (from a shady hole in the wall dealer) but started to not want to go back in 1st. I will be doing this work myself as well but unsure about how to tackle this project. Should I get it rebuilt or figure out what could be causing it to not shift correctly?
Old 08-25-2011, 05:26 PM
phildelfino's Avatar
do it yourself. there are places to buy the solenoids. read this from another forum.
good luck with it all.
http://www.pirate4x4.com/forum/showthread.php?t=587521
Old 08-25-2011, 07:50 PM
Right on. I had a couple people say something about the solenoids before. I'll definitely check that out first.
Old 10-18-2011, 10:42 PM
Today I started taking the top end apart. I might have a problem with my timing and I need some advice with the fuel injectors. Here are a few pictures from today.
pulled off the injectors on the right side and found this
I'm wondering if I have to worry about my timing...
does this mean my cranks off a notch?
Old 10-29-2011, 05:28 AM
Schism64's Avatar
If I were you, at a minimum I would replace all the seals on the injectors and clean them. I had mine sent out to a guy I found on the boards and he cleaned, tested, replaced all seals for a little over $100 bucks. Well worth it.
If you are redoing the head gaskets, the timing notches are irrelevant. That being said, the timing may and/or may not be off, can be hard to tell with these engines. Getting all marks exactly lined up is not always possible. Not something to worry about.
Old 10-29-2011, 05:33 AM
92 TOY's Avatar
I used www.witchhunter.com twice for injector service. send off the cold start injector too while you are at it.
i have lots of pics from our recent 3vze rebuild (my son's thread in my sig), so hit me up if you need something.
Old 11-01-2011, 10:58 PM
I have been hearing from a lot of people to get the injectors cleaned. I can afford that so I guess I'll find a local shop....maybe witch hunter. I also looked into cleaning them diy...found this video on youtube http://www.youtube.com/watch?v=VFJlTfHyrUk
I'm tempted to try this myself.
Old 11-01-2011, 11:14 PM
Here are more photos of the tear down
I made this and it works great!
I took the heads off together with the exhaust crossover....I wasnt even going to attempt trying to bust a knuckle haha
It is obvious that the gasket failed at the no1 piston. a peace broke off and now my piston is dinged up...wondering if I should grind it smooth?
I have already ordered the gasket kit, knock sensor wire, pintle caps for injectors, and should be taking my heads in to a shop tomorrow for testing and all that good stuff....then its off to pick a part for a camshaft, egr bolt, exhaust bolts and those random parts ive been needing.
Old 11-02-2011, 09:13 AM
JohnVH's Avatar
subscribing, Ill be in this boat on a '90 3.0 soon. Whats that thing you welded up on the head, Im looking for tips before tearing it down.
Thanks
Old 11-02-2011, 10:07 AM
1800's kinda guy's Avatar
if the heads have been done before, and somebody had them resurfaced, then that will make the timing marks not line up completely because there is a very small difference in distance from the crank shaft to the cam shafts.
looks good to me. you'll find out soon enough when you go to time it.
Old 11-02-2011, 01:29 PM
Thanks
awesome! I would definitely recomend buying a quality gasket kit from engine builder.com or just order from the toyota dealer.
That thing I fabricated from angle iron and two thick bolts is a copy cat design of the Special Service Tool required when removing the cam sprecket gears on both heads. !loosen left! It worked great! I couldnt find one anywhere and the dealer told me I had to purchase a kit costing about 400 I saw a few people fab up their own...I can weld so I made my own.
Old 11-02-2011, 01:37 PM
hmmmm....I was able to get the timing marks lined up...I am hoping it is correct since I took a few days to research it. I'll post pics when I get them belt back on. hope it goes smooth.
I discovered today that the front left no1 bearing cap bolt stripped the threads in the head....so I have to retap that. Any advice people?!?!?
I just took my heads into a great mechanic! Candy Man in Bloomington Ca. small place but they have been in business for a long time. Great guys! only costs 120 for valve job cleaning and resurfacing. I dont think it was resurfaced before from the looks of the heads but I could be wrong. I was told that the head gaskets were never replaced. but the timing belt was replaced 29k miles ago. I will be putting a new belt, pullys, tensioner, water pump and all that good stuff on in a few months.
Old 10-24-2014, 12:57 PM
serenity73's Avatar
blown head gasket repair 1995 4runner
Hello yota peeps, I am new to this forum and hope it proves useful. My 95 4runner has been very reliable. However at 206k miles, i finally blew a head gasket and have had blue devil gasket sealer suggested to me, but this seems to be a band-aid solution. I have consulted a mechanic in the bakersfield area who cannot guarantee repair on 3.0L V6 gasket repair for that engine type because 3.0L engines supposedly notorious for this problem, but I have had this truck for 8 years and first time this has happened. So, should I attempt gasket repair? Or replace with used 3.4/4.0L engine?
any suggestions will be helpful. Thank you.
Old 10-26-2014, 03:02 PM
thefishguy77's Avatar
It depends on your skill level. If you know that you could rip it apart and put it b k together then it's not a bad idea. Some people will tell you to get a short block with low miles and swap it in. Some will say a 3.4 is the only way to go. It all depends on time money and skill level. If it were me and I was going to rip it apart then I would probably do the bottom end at the same time. Might as well have a new motor right. So give us some more information about your skills and wants/needs and oh yea money. Hope this helps
zd92655
03-06-2022 12:58 PM
naward1996
04-23-2018 05:23 PM
voiddweller
19
05-02-2016 09:10 PM
Alaskan91
09-21-2015 04:39 AM
paxanders
06-21-2015 06:29 AM
Quick Reply: Replacing head gaskets on a 1995 4runner sr5 3vze
