Rear view mirror
Old 08-09-2012, 07:51 AM
KnightFiyah's Avatar
Rear view mirror
So my buddy messed with my rear view mirror and the screw fell out, and I tried to screw it back in, but it seems like something that was holding it in place has fallen inside the rear view mirror somehow..
Thoughts? Should I buy a new mirror? If so, how do I install it?
Old 08-09-2012, 08:21 AM
Inferno451's Avatar
There's a little peice that it screws into that is loose. Pop off the plastic cover, you can usually just get it off by hand. There should be 3 or 4 screws that hold on that part too the roof. Unscrew those and it will come down, you should be able to figure it out from there. Easy peazy.
Old 08-09-2012, 06:56 PM
You must be thinking of a different model 4runner with that mirror because you can't pop off the plastic on mine. Anyways, the part seems basically broken. Any ideas for a replacement? I'm calling the dealership tomorrow, but I'm open for alternatives as long as they're the OE rear views.
Old 08-10-2012, 11:12 AM
...that wasn't even relevant to what we're talking about...
Old 08-10-2012, 11:49 AM
Fink's Avatar
When I had my '95 I replaced the mirror with one from www.carpartswholesale.com - fit was great and it was about 60% cheaper than from the dealership.
I doubt that the mirror is broken, by the way. Have you tried removing it to see if there is a way to get the loose piece of plastic out of there and figure out what it is?
Fink
Old 08-10-2012, 12:01 PM
rokblok's Avatar
Shoulda seen what he put in the tire/wheel section under the "what size rim" thread... Uhhhh......
Old 08-10-2012, 12:24 PM
Fink
Well the mirror isn't broken really, just the other side of the pivot (black plastic) isn't fitting back in right. I was able to lock the screw back in with the metal plating after fiddling with it for about an hour, but if I can't get the swivel's pivot back into the mirror, then I'm SOL.
I checked that site, and others, and the "OE replacement" looks somewhat similar, but my lights above my mirror are different and I'd like to keep them that way. The only place that has my exact part is ebay and places like that, where the part is kind of damaged which I don't like anyways.
Looks like I'm going to pay $170 at the dealership...*shakes fist at toyota*
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
lledwod
08-30-2016 01:03 PM
coreyedwards7611
01-16-2016 06:38 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: Rear view mirror
