Which rear axle shaft will fit my 96 4runner?
Old 09-30-2009, 10:54 AM
jvh4513's Avatar
I own a 1996 4runner limited w/ abs and rear locker. I hit a curb when I slid out during a rain storm. I have a pretty bad wobble on my rear driver's side axle? I switched the spare tire on and it's the same.
I am looking to buy the backing plate/axle shaft assembly from a junk yard.
I have the coding page from sonoran steel but... I am wondering..
I know it has to have abs and the 4.3 gears, but does it have to have the rear locker?
Which years will fit mine?
Any other advice, is this something a somewhat experienced diy-er can undertake?
Thanks in advance guys!
Old 09-30-2009, 11:31 AM
eric-the-red's Avatar
AFAIK the axle shafts are all the same for 96-02 4Runners, and maybe Tacos of the same vintage. If you're just replacing the axle shaft on one side it won't matter what gears are in the diff. You will need one with ABS so it has the wheel sensor.
Make sure you replace the seal in your old axle housing before putting a new shaft in. And you might want to consider replacing the other seal while you're there.
Instructions are here
http://www.4x4wire.com/toyota/mainte...axle/oil_seal/
Old 09-30-2009, 12:16 PM
jvh4513's Avatar
How will the gears not matter??? and all years 96-02... how do you know this?? This crap is driving me crazy lol
Old 09-30-2009, 03:22 PM
I assumed you'll be keeping the 3rd member from your old axle and just replacing the inner shaft that goes from the diff to the wheel. If you're planning on replacing the entire rear axle then you'll need one form a 4Runnner, as the Taco ones have leaf springs. But even then if you get one with different gears you can still swap in the diff from your old axle.
And I'm not 100% sure all 96-02 are the same but they're definitely all the same length, and I haven't heard of any different spline patterns.
Old 01-06-2014, 06:55 AM
osideEVO's Avatar
Hello I'm new here, sorry for bringing a old post back alive but I need some help...I have a 2000 4runner with 16" wheels. So I have a bad wheel bearing/shaft and was wondering if I can replace it with a shaft that came from a 96-00 4runner with 15" wheel?
6th Gear
19
12-10-2019 07:31 AM
DanStew
06-29-2015 10:46 AM
cchinny
06-25-2015 08:11 PM
Niameyrider
06-25-2015 05:50 AM
Leonel
06-13-2002 02:42 PM
Quick Reply: Which rear axle shaft will fit my 96 4runner?
