Quick question on brake line nuts.
Old 09-19-2010, 01:42 PM
camo31_10.50's Avatar
just to clarify, my brake lines and clutch lines all have Flare Nuts on them...Correct?
and to PROPERLY remove them without fubarring the nut itself, i need a Flare Nut Wrench....correct?
particularly 10mm flare nut wrench, right?
Old 09-19-2010, 02:32 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
right...
Also, removing seized on nuts is a PAIN, so use grease or anti-seize on them.
That way, you won't break an El' Cheap-o like I did, and in an emergency situation you can remove them with just an open ended or adjustable wrench, and (hopefully) not round off the bolt doing it...
Old 09-19-2010, 02:34 PM
i appreciate that!!!
yea but every time i use a regular open ended wrench, i strip the nuts...EVERY TIME!!! lol
Old 09-19-2010, 02:38 PM
Be glad you're not me!
The only one line for a right side caliper I could get off without rounding it, was a left side...
I 1st bought a Harbor Freight set, lost my 10. Then bought a 10 at AZ... Brought it home, ripped the caliper off and broke that 10 off...
Bought some anti seize when I took that wrench back...
Ohhh, fun times... I tell ya...
My advice, get a set or a well made ($$$) one... It will pay off as the tolerances should be higher: I.e should fit tighter (less apt to round off a nut) and be stronger.
Old 09-19-2010, 03:54 PM
thanks!!
one of the reasons for making this thread...was because my father doesn't believe a 10mm flare nut wrench is different than a regular 10mm....:/
Old 09-20-2010, 12:57 PM
wyoming9's Avatar
Red face
I think the proper term is line wrench.
Most people call them flare nut wrenches
To bad about the fatherinlaw some people are clueless when it comes to tools
If i remember the power steering hoses are 17mm
Old 09-20-2010, 12:59 PM
yea i figured flare nut wrench isn't what it's called...but that's what i hear them called all the time.
he's my real father...not in law or step father
he's knowledgeable on alllll kinds of tools..but has always used regular 10mm wrenches on brake lines and clutch lines...and has almost ALWAYS rounded them off...that's why i enlightened him about the Flare Nut Wrenches
Old 09-22-2010, 01:06 AM
angrydogtattoo's Avatar
Craftsmen set cost me $30 for 5 wrenches goes from like 9-18 mm, best money spent, now if you know your going to replace the brake line, like the 8" solid on the front brakes and the PO buggered it all up before you, use a screwdriver or cutters and cut the line and use a socket, so you save the flex line from damage.
Old 09-22-2010, 04:44 AM
waskillywabbit's Avatar
Good set of channel locks work best I have found for brake line fittings if breaking loose.
:wabbit2:
Old 09-22-2010, 08:11 AM
just bought a 10mm/12mm flare nut wrench, Duralast, lifetime warranty, it was about $7 i believe from AutoZone
Old 09-23-2010, 09:12 AM
Staff
DeathCougar's Avatar
:wabbit2:
If you don't plan on reusing them maybe.
Line wrenches aka Flare Wrenches work the absolute best. If it still won't come free, plan on replacing the lines.
Old 09-23-2010, 09:21 AM
Taken dozens loose with a nice pair of channel locks and reused no problem Mr Negative.
:wabbit2:
Old 09-23-2010, 10:09 AM
Staff
Hopefully my SS brake lines don't show up with Channel lock marks on them ya backwoods hillbilly no-tools having redneck
Old 09-23-2010, 02:29 PM
lmao well i tried using a pair of vice grips...but that's how i broke it..lol
it's all good now! fixed up all nice and neat!
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
icentropy
07-14-2015 10:23 AM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Quick question on brake line nuts.
