puting carb on 22re
Old 01-07-2010, 07:33 PM
sictimmy's Avatar
puting carb on 22re
i have a 88 2wd toyota p/u with 22r carb in it, i have a 22re .50 over cam crank head decked port polish blah blah blah. i wanna put a carb on the 22re and sink it in the 2wd, do they make a kit for this? will the efi cam still work? would i be best off puting a built 22r head on it? i know efi is better but i figured its easyer to put on a carb then to swap the whole truck to efi have to harrnes swap and every thing. any advise would be cool thanks
Old 01-07-2010, 07:40 PM
camo31_10.50's Avatar
uhm..you would be MUCH happier just doing the EFI conversion to your '88...
BUT, you can just bolt up your carb. intake manifold to the 22RE head and hook everything up, like fuel lines, vacuum lines, choke, throttle linkage and all that jazz...i suppose the 22RE cam should work?? i don't think there is any difference between the 22R cam and the 22RE cam, and if there is it's minor and shouldn't affect anything
Old 01-08-2010, 01:55 PM
sictimmy's Avatar
to do the efi conversion i have to do a full harness swap put in a efi gas tank fuel pump ecu, or just splice the front part of the efi harrnes into the 22r harrnes right?
Old 09-05-2011, 07:19 PM
tstein1024's Avatar
Is it possible to have a carb 22RE? Bought pickup off a guy that claimed it was rebuilt and had to replace front main seal and pulled the threads out of timing cover when I was bolting the water pump back on, bought new head for 87 22RE and it was too short...any ideas?
Old 09-05-2011, 07:40 PM
1989pickup's Avatar
I'm running a weber on my 22re. I got rid all the electronics besides the ignition and essentials(headlights etc..) but the whole computer and everything got taken out. It runs great no problems at all
Old 02-06-2014, 07:22 PM
TJW85's Avatar
Hi I have a 1985 p-up w a 22re w?efi.I cant get the efi to work ,have no injector pulse&I keep frying brains.i want to rip the EFI out and convert to carburater , can u tell me wat I have to do to convert it to carbureted/weber
Old 02-07-2014, 12:48 PM
85TurboRunner's Avatar
No you're not. Since it has a carb. it is a 22r now.
Old 02-07-2014, 12:49 PM
What???
daddio
08-09-2015 07:17 PM
tomczaksdiesel
07-26-2015 10:35 PM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: puting carb on 22re
