Possible rear end noise, via high pitched whine
Old 08-02-2010, 07:10 PM
bfdrunner's Avatar
I just bought a '97 4runner, and when i reach about 30mph or more it sounds like im driving on dry pavement in 4 wheel drive. Its pretty whiney sounded it does have a little bit of a raw metal grinding sound too. Doesw it sound like i need a new rear end? If so, what should i expect for this repair.
Thanks guys.
Old 08-02-2010, 07:34 PM
PismoJoe's Avatar
Very vague information you posted, we need some more info
Does it do it all the time? 2wd/4wd/Neutral
Why are you leaning towards the rear end? Have you pinpointed the noise to the rear axle?
Old 08-02-2010, 08:05 PM
bfdrunner's Avatar
Sorry. Yes it does it all the time. As I accelerate it gets louder and if I let off the gas it gets quite for a second then you can hear it again. A mechanic drove it and said it was the rear end. I thought that it was the wheel bearings but doesn't get louder if I turn left or right. I can't tell where it's coming from. Just going by what the mechanic said, but he's not a Toyota guy
Old 08-02-2010, 11:30 PM
peow130's Avatar
Definitely seems like a rear diff issue.
Doesnt it sound sort of like a V12 Ferrari growling?
Or, possibly an electric motor whirring?
Mine sounded like the V12 and it turned out to be the pinion bearing took a dumper.
Old 08-03-2010, 04:09 AM
bfdrunner's Avatar
Thanks peow130. How
Much did your repair cost?
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
icentropy
07-11-2015 07:21 AM
MTLroadierunner
07-06-2015 12:17 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Possible rear end noise, via high pitched whine
