Oil Pump Drive Spline
Old 09-25-2007, 01:20 PM
81redbluffyota's Avatar
Location: I live in Red Bluff ca. Right by the Sacramento river
I have asked a few questions on here and you guys have been pretty helpful, and we all know the best way to learn is to ask questions. So, I need to know how I get the oil pump drive spline off, in my manual it doesnt mention, needing special tools, and shows a picture of a hand removing it. I pull on mine, and it doesnt move, stuck a screwdriver behind it, and it moves a little, but doesnt seem like the right way to take it off, and I dont want to hurt anything. Do you guys know what I should do? For those who dont know, Its the gear that sits on the crank right behind the oil pump cover.
Old 09-25-2007, 03:48 PM
bump bump
Old 09-25-2007, 06:27 PM
landozion's Avatar
Well, you dont say which motor you have, but from your sig I am going to guess an 81 with a 20r? I have no experience with a 20r, but on my 22r its like you said, it just pulls off. Hope that helps.
Old 03-05-2011, 10:51 AM
KatKrazy's Avatar
I want to know how to get mine back on the crank. Mine is a 22re. Doesn't want to simply slide on. Any tips? Is it supposed to be super tight like that?
Old 03-05-2011, 04:57 PM
slacker's Avatar
most likely the crank keys have been flattened .. sometimes when they are installed , people use hammers .. and they then will bind .
removal can be accomplished using a gear puller
as for the above post .. Yes , it should slide on fairly easly .. I would say look at your crank key .. it's probably restricting the install
Old 03-05-2011, 05:03 PM
xxxtreme22r's Avatar
yup, FYI, those crank keys should be replaced every time you have the crank pulley off. But if they are kit with a metal hammer when putting them into the crank, then the tops will mushroom out making it difficult to put the pulley back on.
Old 06-30-2011, 08:10 AM
86bedlesstoy's Avatar
I have this problem!
Old 07-15-2011, 10:32 PM
Guessing you got it off..
Old 07-15-2011, 11:05 PM
myyota's Avatar
The oil pump on my 86 4Runner grenaded its self and the drive gear. When i removed the oil pump it was nothing but chunks of metal inside. I had to replace the drive gear and oil pump, and everything came a part very easy, even the drive gear on the crank shaft, it just pulled off and the new one went right back on.
Old 03-29-2015, 09:13 PM
blue22's Avatar
harborfreight:Gear Puller Set 14 Pc
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Oil Pump Drive Spline
