oil filter removal
oil filter removal
i have a 94 runner with a 3vz and i think i tightened my oil filter to tight last time i changed it. Iwas wondering if it possible to take off the filter with out draining the oil since its on the top part of block not bottom. just trying to not have to dump oil to check the filter. any help is greatly appreciated.
you can take the filter off without having to drain the oil, though some WILL spill out. About a half quart round about, good idea to have more on hand to top the level off when you are done. but there is no problem with taking it off. i would suggest, though, that if you over tightened it and are planning to take it off, go ahead and replace it. not because its damaged already, but chances are the you will damage it while removing it.
Also, when you do take it off, make sure the little rubber o-ring isn't stuck to the block. happened to me once when I overtightened one. It stuck to the block, so when I put the new one, it didn't seat right, started driving down the street and my neighbor started yelling at me that i was leaving a trail of oil.
yeah its leaking a little from the filter. i am just gonna get a new filter from napa or toyota and replace it. never thought of the screwdriver idea. might get a little messy though but it is funny. thanks for the help. now i just gotta fix my leaky slave cylinder in passanger rear brakes and all the leaks will be gone.
I picked up an oil filter vise grip at Harbor Freight a while back. No filter has ever stood up to the vise grip, they all turn the first time. I used to do the screwdriver technique on a stuck filter, but that is too messy. Link below:
http://www.harborfreight.com/cpi/cta...emnumber=66568
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
