The OFFICIAL IFS "What size tire will fit" thread
Old 05-04-2009, 03:00 AM
  #61
kcpanages's Avatar
For the guys who like big, im running 38.5x15x16 boggers. 7" springs, 2" shackles, 3" body. NO RUB AT ALL......
Old 05-04-2009, 03:06 AM
  #62
kcpanages's Avatar
Originally Posted by taco47
New here to the forum, just installed bilstein 5100s set at 2.5" and a rear 2" AAL in the rear, i was wondering if i could get 285/75/16s under it or am i stuck with 265s? some have said that it will rub on my UCAs and body mounts.
Im not good at metric sizes. But i had a 2.5 lift on my 03 taco and ran 29x10.50 super swamper sx on stock rims . no problem. then i added a 3" body and ran 33x12.50x15 tsl radials. i used procomp rims with a crazy offset. no rubbing. then i took the 2.5 suspinson lift off and put a fabtech 6" suspinson plus the 3" body i already had and cleared 37x14x15 IROKS with no rubbing...... hope this all helps u with ur taco
Old 05-04-2009, 02:50 PM
  #63
jjrgr21's Avatar
255/85/16's rub in the rear of taco's when using ome leaves, because they bring the axle foward a bit. this can be fixed by buying relocation plates from various places, got mine from sky
255's fit in the front fine with tundra springs.
Old 05-05-2009, 07:34 PM
  #64
taco47's Avatar
ok thanks guys
Old 05-08-2009, 10:50 PM
  #65
curtwong8's Avatar
Will these tires work???
Hi, sorry if this answer is on here but I did a search and couldn't find anything. Does anyone know if 265/75/r16 tires will fit okay on an '89 4x4 Pickup without any issues besides the speedometer? The tires are Goodyear Wrangler "territory" Thanks
Old 05-08-2009, 10:55 PM
  #66
mrmatson's Avatar
If you have 16in wheels then yes they would work. Stock wheels are 15s tho.
Old 05-08-2009, 11:35 PM
  #67
curtwong8's Avatar
thanks for the reply...yeah I've got some older (2000 I think) 16" 4runner rims to put them on....just concerned about rubbing
Old 05-09-2009, 12:21 AM
  #68
Matt16's Avatar
They should fit with the 16" 4Runner rims (correct backspacing I would think).
Old 05-09-2009, 06:03 AM
  #69
Alex 400's Avatar
they should work. 32x10.50 equivalent.
Old 05-09-2009, 08:29 AM
  #70
curtwong8's Avatar
Thanks, any issues with gearing going to the 265/75/r16 (or 32's) that may need to be done?
Old 05-29-2009, 12:28 PM
  #71
1st-Time_Runner's Avatar
Ok I see that some of the more experienced yota owners get tired of hearing this question, but here it goes. I have 07 4Runner with stock 265/65R/17 and I really like the stock rims however I want a more aggressive tread so. What do I need to do to get a similar look like creighton43? I really like that by the way. I hope this does aggravate yall too much but this is "The OFFICIAL What size tire will fit thread" and all. Thanks a head of time for the info.
Old 06-04-2009, 07:22 AM
  #72
Birchyboy's Avatar
I've got 15x8 wheels with +6 offset. Is this offset going to help or hurt with either 31/10.5/15's or 32/11.5/15's on a stock '93 with running boards. I bought the wider wheel in hopes that it would be good but am unsure what the offset does for me.
Old 06-23-2009, 06:48 PM
  #73
paynemw's Avatar
so i have a 2000 4runner SR5 4x4 and I also have but and getting rid of a 1990 chevy k1500 with the stock aluminum 16in rims wrapped in 265/75 Kumho Road Venture AT's.... and i checked the Pro Comp Wheel conversion chart for bolt patterns and am supper suprised but it says that the 4runner and the chevy have the same bolt pattern. I am stoked because the Kumhos are brand new and why not just throw my Kumhos and rims on the the 4runner... is it possible? if not why? the 4runner has 22575r15... help me! 3 in suspension lift is soon to come
Old 06-23-2009, 07:26 PM
  #74
4Crawler's Avatar
Check the center hole diameter and make sure it is large enough to clear your front hubs. You can also check the back spacing and see if that will work as well.
Old 06-26-2009, 04:25 PM
  #75
ESQ
ESQ's Avatar
Got a Sonoran 1.2 suspension lift on a 98 4runner (3.5"R, 2.5F")
Can I run 285/75/R16 without rubbing the upper control arm?
Thinking about getting some FS Destination M/Ts.
Old 07-24-2009, 12:40 AM
  #76
bezrq surf's Avatar
I have been searching for an answer to this... I have a 91' hilux surf with 3" body lift and 3" suspension and just put 35x12.50R15 KM2's on and want to know if its to big a tire for the stock gearing and IFS ?, I think it would have looked dumb with 33"s. I bought it with the lift and 35x12.50R15 MTR's and they rubbed the back of the wheel well at the bottom if i hit a bump at full steer lock just a bit and only till they wore out a bit, but looked good.
Old 07-24-2009, 03:35 PM
  #77
paynemw's Avatar
don't every do any kind of modification like suspension or tires because it "looks stupid" remember you gotta build the truck to work, not look cool. its like seeing ricer's on the street with loud exhaust and chrome but no engine to back up the looks... that is STUPID
Old 07-25-2009, 09:24 PM
  #78
bezrq surf's Avatar
im not really hard on my truck though, and the added clearance is nice for in the mud in deep ruts since most people have made ruts with 40"+ tires up around here. I was just wondering if the tires will wreck it man.
Old 08-06-2009, 04:13 PM
  #79
BeNoC's Avatar
i have a 1990 pickup 3vze. I want to put some 31x10.5 on 15x8" rims with 3.75 backspacing. How far will the tires be out of the fender? i like the look. i assume i will have rub, would a 2 in. body lift eliminate any potential rub?
Old 08-21-2009, 01:19 PM
  #80
TurboManiacal's Avatar
2008 Sport Edition 4Runner Stock Height.
Currently running stock 265/65/17's
Planning on purchasing BFG All-Terrain T/A's in 265/70/17 (same size as FJ Cruiser). All research points to no rub issues - barring anyone chiming in, will place an order in the next 30 days.
Quick Reply: The OFFICIAL IFS "What size tire will fit" thread
