Looking for wiring info for alarm install
Old 06-06-2010, 05:53 PM
domino760's Avatar
I need the wiring locations and color codes for a 2000 Toyota 4Runner Ltd V6 2WD please! I have a $400 alarm that I'd like to utilize but I can't find this info ANYWHERE.
Old 06-06-2010, 06:14 PM
jdmmike's Avatar
go to: the12volt.com
Old 06-06-2010, 06:16 PM
jdmmike's Avatar
2000 Toyota 4-Runner Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White or White/Red Ignition Switch Harness
Starter Green/Black Ignition Switch Harness
Ignition Black/Red Ignition Switch Harness
Ignition 2 Black/Yellow Ignition Switch Harness
Accessory Blue/Red Ignition Switch Harness
Tach Black (AC) Diagnostic Connector
Brake Switch Green/White Brake Switch
Trunk Pin Light Green/Red(-) Driver's Kick Panel
Parking Lights Green (+) Light Switch
Head Lamp Blue/Black (-) Light Switch
Hood Pin Green/Orange (-) DR. Firewall in Gray 26 Pin Connector
Factory Disarm w/Locks
Door Trigger Black Driver's Door Rear Doors Black/Red Driver's Kick see notes
Door Lock Red/White Driver's Kick Panel 18 Pin Conn.
Door Unlock Red Driver's Kick Panel 18 Pin Conn.
Driver's Lock Blue/White Left Kick Panel
Driver's Unlock Pink/Green Left Kick Panel
Passenger Unlock Red Left Kick Panel
Horn Wire Green/White (-) Switch above Brake Pedal
Windows Up LF=Light Green, RF=Red/Black, LR=Red/Blue, RR=Yellow
Windows Down LF=Blue/Yellow, RF=Red/Green, LR=Red/Yellow, RR=Green
Old 06-06-2010, 06:25 PM
domino760's Avatar
Thank you!
Old 06-06-2010, 06:32 PM
jdmmike's Avatar
np, good luck w/the install
MO transplant
04-23-2023 11:58 AM
icentropy
09-16-2020 02:47 PM
88yodabasket
07-13-2015 01:32 PM
crashburnoveride
07-10-2015 06:39 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Looking for wiring info for alarm install
