Lift Kit, should I use blocks or add a leaf?
Old 11-05-2010, 10:35 AM
bman120's Avatar
I'm looking at putting a Revtek 3" lift on my 2005 taco I'm wondering if I should put blocks or add a leaf for the rear lift. Which is more ideal for off-road?
Old 11-05-2010, 11:02 AM
4banginRunner's Avatar
Neither, get springs.
But out of the 2, I'd get the AAL's.
Old 11-05-2010, 11:03 AM
bman120's Avatar
okay why springs?
Old 11-05-2010, 11:05 AM
yotarob2005's Avatar
Blocks just plain suck and an AAL will stiffen your current springs. OME Dakars replacement leaf pack is the best solution, but the AAL will be fine for now.
Old 11-05-2010, 11:13 AM
Your gunna get mixed reviews on blocks here, more towards the don't use them spectrum. I'm running 2" blocks now, mainly since I have to to keep my 63s up with my 4" springs up front. All they are, are for height and when used improperly are a major safety hazard and put alot of stress on the springs.
AAL's will stiffen your ride, and eventually wear out and your back to "stock".
Lift springs are the best choice b/c your not depending on any add-on's, no extra unneeded stress points on the springs. And you'll get more performance and predictability out of springs
Plus you will look cooler at the mall
Old 11-05-2010, 11:14 AM
bman120's Avatar
are the OME Dakars something I can add on later if I go with the AAL for now?
I'm liking the idea of not putting extra stress on the springs though. Besides the Dakars what are some other really good ones out there?
Old 11-05-2010, 11:17 AM
You can put an AAL in there for now & get some dakar's later if you want, AAL's are cheap, Dakars are not
Old 11-05-2010, 11:19 AM
87hillbillyoter's Avatar
i have huge blocks in the rear from the PO, and i say just get springs. it rides like crap and im always worried somethings gonna break.
Old 11-05-2010, 12:24 PM
Outsane's Avatar
Zuk Mod is my vote..
I did it and love it so far
Old 11-05-2010, 12:33 PM
A little unrealistic on an 05 Taco
Old 11-06-2010, 02:35 AM
91 4Runner's Avatar
Another popular choice (if you can weld)
http://www.sontt.com/forum/viewtopic...sd=a&start=160
Old 11-16-2010, 12:45 PM
Mean1982's Avatar
I run all springs, but when the day comes to get more lift, an inch or so of block is not a problem.
Old 11-16-2010, 11:13 PM
limon32's Avatar
Can anyone tell me why blocks stress the springs?
Old 11-17-2010, 04:33 AM
ScottyC's Avatar
It leads to a lot more spring wrap when wheeling. Think of it like adding a long breaker bar to a lug nut compared to trying to break a lug nut loose with a 1/4" drive ratchet.
When torque is applied to the rear axle, the pinion wants to walk up. The springs keep it from doing that. Add a block, and its MUCH easier for the springs to wrap up since you just add a breaker bar to the application.
For street use a block is okay. For offroad use is a no-no.
Old 11-17-2010, 05:02 AM
waskillywabbit's Avatar
Scotty
I'd get a better quality lift kit period.
Front spacer lifts are going to ride like anyway so blocks or aal in the rear is irrelevant here.
With a real lift, coils and shocks up front, get an aal for better ride with a load/towing and blocks for looks. If you are gonna wheel, new leafs and shackles.
:wabbit2:
Old 11-17-2010, 08:34 PM
limon32's Avatar
I got 3.5" blocks cause I didn't have much money at the time and I figured I'd run 'em untill I broke something, that was 2 years ago... Seems pretty cost effective, at least till they break!
I can't wait for some new 4" leafs though, having said that!
Old 11-17-2010, 08:42 PM
Fossilized
Staff
dropzone's Avatar
on an '05 Taco (I miss mine:pissed) the OME Dakar are about the only way to go.
I have also heard of a few people (on ttora.com) having custom packs make by National spring
Not sure if Deaver makes springs for '05 + tacos yet
axle wrap from blocks can be noticable...got rid of the 3.5" blocks on my current project and the right improved a lot
Old 03-19-2023, 01:17 AM
Abe111's Avatar
I don't think I need to increase it. After all, you are easy to damage when you go cross-country
Old 08-14-2023, 01:57 PM
mydanielcreg_3's Avatar
natemoses13
02-13-2013 06:29 AM
CJM
04-25-2009 10:32 AM
scuba
01-24-2008 10:47 PM
Quick Reply: Lift Kit, should I use blocks or add a leaf?
