leaking antifreeze at thermostat housing.
Hi all. I recently replace my thermostat on my 1990 22re truck. Now it is leaking at the thermostat housing. I used the rubber O ring on the thermostat and tightened the bolts as tight as I am willing to do. Should I try some rtv instead of the O ring or make a gasket and discard the O ring altogether? Anyone else have this issue? Thanks in advance.
Deano
Deano
trailgoat
08-13-2015 05:54 PM
