jumping speedo needle
Old 09-21-2012, 05:22 PM
mickyd9990's Avatar
hello all!! first post on here and thanks to all who may be able to give some advice..
i have an 89 pickup that im currently building a flat deck for..
so while its off the road figured i would fix some other problems..
so replacing the whole antenna and cable.. as well as radio..
so while the dash is apart i want to tend to that speedo needle that jumps all over and makes a horrible screech sound when its real cold out..
has anyone experienced this before.. will some lube on the cable take care of it or will i need a new cable fix it?? i only want to pull the dash apart once to do radio and this but do not want to leave it all apart if i will def need a new cable.. thanks for any advice you can lend..
Old 09-21-2012, 06:03 PM
rokblok's Avatar
Welcome to YT.
I would try the cleaning and lube it 1st. It's not terrible to remove and you don't have to remove the dash. Just the cluster and some under dash parts. I would take out the whole cable, wipe it clean, spray out the housing with a spray cleaner, maybe even degreaser, and re-lube everything, stick it back in. Or just replace the whole thing.... The search function will work tremendously for you.
Old 09-21-2012, 06:19 PM
mickyd9990's Avatar
good deal thanks for the input
Old 09-22-2012, 07:20 PM
slow-mo's Avatar
I had a jumping speedo issue as well. Even with lubrication, it ended up failing. I bought a new one and the speedo-meter is smooth-as-silk.
Old 09-23-2012, 03:52 PM
mickyd9990's Avatar
awesome.. did you go with an oem or aftermarket slow-mo??
Old 09-23-2012, 05:23 PM
slow-mo's Avatar
I went OEM. I bought it at toyotapartszone.com.
Old 09-24-2012, 12:41 PM
mickyd9990's Avatar
thanks man
Old 09-24-2012, 03:54 PM
Motox711's Avatar
If you do end up lubricating it use graphite. I did this and never had any issues since.
83yotastockR
11
11-10-2015 06:54 AM
Chicken12
10-14-2015 03:54 PM
charlie_fong
09-27-2015 10:06 PM
Rcbc92
09-26-2015 03:00 PM
jacked_72
09-14-2015 03:31 PM
Quick Reply: jumping speedo needle
