ITBs on a 22R?
ITBs on a 22R?
I searched around here but didn't find much. ITBs are independent throttle bodies. They aren't that hard to do on Inline motors. You see them on all-motor Hondas a lot. It would be a sick setup though.
I was just curious if anyone has attempted this on a 22re? Unfortunately, I think the computer would have to be modified.
im sure it would be possible for a 22R / RE but the problem is that the 2 valve setup makes it extremely difficult for the motor to use that much fuel/air and on the fuel injected models the stock injectors would also limit the usefullness of such a setup because they would not be able to compensate for that much extra air.
most of the motors ive seen with ITB use 4 valve configuration so that they can get all that extra aspiration down to the combustion chamber.
Jadri, is that four cylinder ITB picture for a 22RE?
I've been searching (and lurking) for a while now, but have been unable to find a picture of a 22R(E) with ITB's. So glad someone finally started a thread.
I've got an 85 (yeah! hell of a block!) two door 2wd longbed truck that I plan on putting ITB's in.
It'll be a street car so I'll be re-designing the 22R in a pretty unique fashion for my needs. I.E. shaving 10mm off the stroke to reach higher rpms.
Megasquirt for fuel management, and i'll probably source throttle bodies from Jamaican or South African AE86's. 45's are good for about 50hp per tb, and the 48's are good for more...but I am unsure of whether I'll be running nitrous or not yet.
Compensate for increased airflow by using bigger valves, port and polish, 20R head, et cetera. custom make a manifold...
Anyway, I'm planning on designing and building the engine over the next 5 years or so in my garage with a total budget landing somewhere around 10 grand for the engine. Should be an exciting project
Please pm me if you know of someone who has ITB's on 22R, i'd be a happy camper
Wish me luck!!! lolz
As a side note, I'm a VW guy and this yota thing is new for me (LOVING IT THOUGH!!) and I was a bit disappointed to find there is no DOHC head for 22R motors... I've searched countless pages and forums, and everyone says no, but I would like to communicate with someone who has tried this first hand. Please flame me for this if you want, but what doesn't match up when you put an AE86 head on a 22R (aside from the bore/chamber)??
The R engine is essentially a truck engine, they're made to rev low, and produce smooth power and torque. You can make 250+ horsepower with one, but for the money spent, I'd get a 3RZ out of a Tacoma and swap that if you're looking for power.
lol, thx for the reply, i was suspecting as much, but really needed some closure. And I'm a water-cooled guy btw.
I like taking the old and making it anew so i'd like to work with the original motor. Power isn't really as important as just strait up restoring and renewing this truck. I'm a bit sentimental about it i guess.
I'm a bit of technical person, so I'd like to have fun with this project and go a little nuts, see if I can mold the engine and project into somewhat of a high-revving fun little truck that I have as a vision and project goal for the car.
Thx again for the reply TrikeKid.
Any ITB's out there???
If you want it to rev high/quick, find a machine shop willing to cut the stock flywheel down or buy a lighter one from LC Engineering (they go as low as 9 pounds). The stocker is 20 some odd pounds(I want to say 25 but I'm not sure). I saw somewhere that the 22RE powered cars had a lighter flywheel than the trucks, may be a cheaper route if you can find one.
Go with a heavier flywheel
Myself, I wish i could afford a 30 pound flywheel from LCE this winter, but it just isn't going to happen.
On topic though. Aren't ITB's impossible on a 22RE because our MAF sensor is waaay over by the air filter?
I could have sworn I saw somebody put ITB's on a 22R. But I can't find it anywhere. I'll keep looking.
BUMP. Id love to know if this was possible, i know theres drawbacks like stated earlier but still very interested. Ive heard of miata guys running independent carbs from motorcycles and just re-jetting them. I would guess you could put big enough jets in to work on a 22r but ive never heard of anyone doing it or even attempting.
hey guys i was thinking about the same thing for my 68 corona, i was looking aty a 22r and in my search i found this article(http://www.gatechlocost.com/wordpress/?page_id=152) take a look at it. hope it can help.
buckz6319
08-05-2017 03:50 AM
Toys4parts
09-26-2015 01:56 PM
