injector pulse problem
Old 05-23-2011, 08:43 AM
mhmacw's Avatar
hello. i was wondering how to check for proper injector pulse signal. i heard you test with key on for 12 volts but shouldnt have 12 volts on both sides? is this true? 1995 3vz thanks, dan
Old 05-23-2011, 11:55 AM
4Crawler's Avatar
Injectors typically will have 12 volts on both sides, one is the supply power. The other side has 12 volts when the injector is off, then momentarily the ECU will ground the one side of the injectors (0 volts) to turn it on for an instant. A typical volt meter won't catch that quick pulse, so you could use an oscilloscope or a "noid" light that flashes in response to the ground pulse.
Old 05-23-2011, 12:29 PM
mhmacw's Avatar
thats awesome! 1 less thing on the list of trouble shooting. thanks a bunch!.
Doug4320
03-24-2018 10:11 PM
RatOmeter
10-22-2015 03:17 PM
steve miller
10-10-2015 01:40 AM
Hiluxtrucha
07-22-2015 10:00 AM
karbin
07-05-2015 11:37 PM
Quick Reply: injector pulse problem
