Ignition Tumbler
Old 06-22-2010, 08:55 PM
Nublin's Avatar
Ignition Tumbler
I recently lost a key to my 1982 Toyota Pickup and so I went down to the auto parts store and picked up a replacement tumbler for $22. I have no idea how to pull the current one out without a key though.
The small notes for replacing the tumbler that came with my new one said there is a pin to depress while the key is in the "acc" position. I don't have a key though so I was wondering if there is another way around this without pulling everything apart.
Old 06-24-2010, 10:07 PM
Nublin's Avatar
hmmmm
Old 06-24-2010, 10:59 PM
wyoming9's Avatar
Red face
There is only one way without out the key
You drill out the pin!!
Now since this is a hard pin and it spins this is pretty much a two person job.
One to drill and one to apply pressure on the pin.
Good luck
Of course you could have a new key made by a locksmith lowest cost is to pull the right door lock cylinder and take it to them or replace the whole steering column . As this is old enough
Old 06-29-2010, 10:39 PM
Nublin's Avatar
Good luck
Thanks that worked for me, but I had to remove the steering wheel to get the bit to go in straight.
Kamaloha
10-16-2015 05:13 PM
zombie_barbarossa
10-02-2015 10:54 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
voiddweller
09-28-2015 11:21 PM
Jason4X4
09-17-2015 08:02 AM
Quick Reply: Ignition Tumbler
