How do you make a 22re a 22r???
Old 04-03-2011, 07:21 AM
half cocked irishman's Avatar
907 is right. I just looked at the differences last night. U would need the new.head and intake manifold for the carberater and new exhaust manifold because the pots on the 22r head are different then the re head. I'm about to do a swap myself if I can't my my fuel problem fixed. SOOO frustrated right now.
Old 04-03-2011, 07:22 AM
I meant the ports are different from head to head.
Old 04-03-2011, 07:33 AM
razed's Avatar
Use the intake and exhaust manifolds from an 86-88 22R, and the fuel pump from the 84.
Will probably have to change out the cam shim from the jasper (RE) engine for the fuel pump eccentric from the R engine.
I think the 84 had an air pump but if not, use the PAIR stuff from a later R engine.
Not really all that difficult, and I have a stock intake, carb and maybe air filter, egr and stuff, and exhaust for an 87 22r carb here... and I think the PAIR stuff too.
Old 04-03-2011, 05:38 PM
DKyotas's Avatar
Thanks everyone for the help again I think I'm on the right path now. I will stay posted.
Old 04-03-2011, 06:08 PM
  #25
DKyotas's Avatar
Just wondering if anyone had an opinion on which weber carb to go with. This truck will spend about half it's time offroad ( I don't want to break the bank)but do like hills. Would appreciate any opinions thanks.
Old 07-11-2011, 11:01 PM
  #26
84underconstruction's Avatar
Question Distributor question
I am getting ready to do the same thing on an 89 runner. Are the distributors very year specific or will anything from say 86 to 89, with vacume advance, work???? This is the last part I need to get and I don"t want to mess up.... Thanks guys
Old 10-05-2011, 09:08 PM
  #27
ExB16ner's Avatar
head the same
I have a LC Enginering Pro Head, it is listed as a 22R/RE Head, meaning that you can bolt on either carb or Efi manifold
Old 10-05-2011, 09:10 PM
  #28
ExB16ner's Avatar
I have both 22R & RE complete engines sitting in garage, they look identical
Old 01-05-2012, 10:15 AM
  #29
mudslinger457's Avatar
I got a 82 with a locked up motor and bought a 22re I'm wanting to just swap everything over I got a weber with block plates all over my old 22r is there anything I will need
Old 01-05-2012, 10:30 AM
  #30
85TurboRunner's Avatar
Old 01-05-2012, 01:46 PM
  #31
I really don't know man
Old 02-08-2015, 08:14 AM
  #32
xsynfulx's Avatar
Ok, so I've had a bit of experience with the 22r engines, specifically the '84. I've rebuilt it several times a decade ago. I had a penchant for buying the engines with +500k miles on them, putting new guts into the engines and people would always buy them off of me, after finding I'd get 30+ mpg.
So, fast forward to now. I recently bought a California truck with NO rust on the frame. The box is beat to crap, like it was used to throw wood into, but I digress.
I'm also looking to put a carb onto the 22re engine to make it back into a 22r. Why? Well, because the 22re is a bit complicated, and I'm not able to run it even leaner than the manufacturer specs provide with the EFI. It's not going to be an offroad truck. It's going to be a freeway "putt-putt" to get me 200+ miles, once per week, to my semi and back. I'm mostly concerned with fuel economy, as my old 22r used to top out at 37-40 mpg, with the 15 inch rims, 28-34 with the 14 inch 'slicks'.
So, I'd need the new intake manifold, new 2 barrel carb, air cleaner, and... ?
Again, it's a 1986, Jasper 22re (EFI), 2.1L (?) that I want to make into a 22r.
All help would be appreciated in assembling a parts list for the machine I'd like to build! I'm far more concerned with fuel economy than power.
Old 02-08-2015, 11:23 AM
  #33
skypilot's Avatar
Originally Posted by half cocked irishman
I'm pretty sure u have to change the head as well. If your going for a wheeler u should just keep the fuel injection as it will always send fuel and always run. If your gonna carberater it then u need to invest it a nice carberater so that on extreme incline/decline or roll over, your motor will still receive fuel and fire.
Granted carberated motors are a hell of a lot easier to work on.
Yes; But now he has to hot wire an ECU to run it.
Carbed is easy, much easier to swap. Someday I will build a swap harness.
Oh; and you need a 22r distributor.
Old 02-08-2015, 11:28 AM
  #34
wyoming9's Avatar
Red face
Find a 22R 85 +
that runs better to buy the complete engine with ECU.
Then you just need to worry about the fuel system to be handle the lower fuel pressure.
Merge the 22R engine harness with what you have.
Either sell or scrap the parts you don`t use.
Best of Luck!!
Old 02-08-2015, 12:14 PM
  #35
xsynfulx's Avatar
Originally Posted by wyoming9
Find a 22R 85 +
Best of Luck!!
Thanks! As I've stated, I'm running an '86, so from the things I've heard in this forum and others, the head's should be the same.
So besides the intake, carb, air filter, I'll need a distributor and fuel pump?
Will I also need the computer? That's the point that will make the whole thing 'not worth it'.
I've got an EFI and as I've stated, I'm just trying to make it run lean as possible. Unlike most of the 22r(e) owners, I'm not trying to make it a gas-monger, mudder, offroad, beast of a machine. I could care less about horsepower or towing capacity. I just want to throw an oversized duffel bag into it twice a week and put down 100 miles each way, all freeway, to work and back, doing close to 70 mph. NOTHING ELSE. It just needs to run and idle smooth.
I've tried to tune the EFI and I keep running into emissions garbage problems, between the O2 sensor, the cold idle sensor, and all of the other things the EFI is otherwise known for using. I want it simple. Stock carb. Stock distributor. Spitfire plugs. I want it to run as lean as possible and still go down the road.
Thanks for the heads up! Any more information about my mission would be really handy? I've got both a Haines and Chiltons to help me out, but it's always handy to ask the advice from people who've been there.
I KNOW it's crazy to want to put a carb on it versus the EFI. Let's move right past that?
Now, will I have to find a matching year carb and intake for the 1986 or can I go to an earlier model like the '84, '85? I don't have the parts yet, as I have just purchased the truck this weekend.
Another point worth mentioning, nothing about this EFI is the way it should be. There are vacuum lines missing, the wrong battery in it, a bad alternator, sensors that are bypassed, the A/C pump was removed, except for the air exchanger, and it didn't even have a thermostat in it. Whomever was owning it before me was fond of cutting wires, removing hoses, and mistreating this cherry of an engine, which I know can be bulletproof for up to +500k miles, while getting better than 30 mpg.
Help? I've got a pretty good knowledge of engines, but I'm somewhere in the middle of the road as far as a gear head. Any opinions are helpful!
Old 02-08-2015, 12:52 PM
  #36
wyoming9's Avatar
Red face
Like I said buy the complete running engine 22R of any year after 85 to 95 when the last ones were installed .
The older style parts are just enough different to cause fit problems.
Your also going to run into Emissions with the Carb as well if it needs to be legal in your state to run on the road.
Then California and Federal 22R engines have different ECU`s in 86 at least.
You need the Carb ECU if it needs to be legal!!
The Carb and EFI ECU are quite different.
The EFI fuel pressure is to high for the carb it needs to reduced
I can understand your reasons !!
Your best bet is to get the Factory Service Manual. Makes it much easier.
You might be able to sell your EFI parts to some one going that route.
Old 02-09-2015, 09:54 AM
  #37
skypilot's Avatar
doing the same thing.
I am putting a 22R in place of a 3VZE. The 3.slo is trashed from oil starvation, and the 22R is just getting a complete overhaul. Its simpler this way until I get all the electronics for the 22RE conversion. I should fix the 3.slo but it never ran right and I don't want to fight with it.
So the 22r head is done, just waiting on the short block. No performance upgrades, just a stock .020 over rebuild.
Old 08-13-2016, 04:03 PM
  #38
Gdawghaiku's Avatar
Extra ports?
Same head should be bolt on. No issues. Only time is if you would change head the and go with 20R head and 22R block(then, it has to be a specific early year 22r block,etc.).... and in that case, you also have to change to "DISH"(?) top pistons, have the block 'decked', etc. It's a bit of work from what I read, and some things can be skipped on that mod(20R head with 22r block)...but if you skip them, like the pistons, then you'd have even less power than with a stock 22r, ....so why bother, right? haha.
Far as the Orig. Poster, ...I thing I guessed right as to what he is thinking..but I'll wait for him to say, lol.
I'm trying to figure out what to do with the extra ports on the head. I am converting to 22r and have the parts i need but when line up the intake manifold there are 2 holes that are left open. I belive i can just block them up but not sure. Got any advice?
What to do with that open port?
Old 08-13-2016, 04:19 PM
  #39
Gdawghaiku's Avatar
Is there a block plate?
On the 22r where the intake manifold bolts on is there a port blocked off towards the rear of the head? I got the intake manifold today and went to match up but there is a port that's not covered. Any ideas?
sandyota
02-04-2021 11:16 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
cars-guy
07-11-2015 07:51 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: How do you make a 22re a 22r???
